Question about Gillette Sport & Outdoor - Others
Yeu sheng lb series circuit breaker used in a bladez sccooter
2 Suggested Answers
  • 9633 Answers
SOURCE: YEU SHENG E209138 30 amp used on two scooter batteries
Any brand of battery of the same amperage will work on your scooter. You can google mobility scooter batteries and find many places to get them shipped to you.
Posted on Dec 06, 2016
Vietnamese translation of the song "quand le soleil etait la"
thee you,love you, hear you, strated at his heart,love you, love you ,love you,hear you, what x alanh you please where he vows, name me state luon heart flutter
all you have to do is right click on any foreighn language then click on translate in the drop down box
May 17, 2017 | The Computers & Internet
Dec 06, 2016 | Health & Beauty
Compressor builds to 100 lb pressure. after a few minutes use, it comes on again to begin pressure build up. next cycle, it trips circuit breaker in house.
You didn't provide all pertinent info available to you. Lets take what we have; and, consider why your compressor is overloading the circuit breaker. Points to ponder:
  1. Not knowing the exact model (not series) I don't know what the amperage pull is for your "extreme" compressor or the circuit breaker's rating. A 25 amp compressor connected to a 25 amp breaker could be an issue. Campbell Hausfeld's support pages are crashing so I can't check the possabilites.
  2. Are you using a lightweight extension cord? The lower the rating of an extension cord the higher the amp pull on the breaker. If you eliminate the extension cord does the problem go away? Ohm's Law applies. <http://www.ohmslawcalculator.com/ohms-law-calculator>
  3. What else is on this breaker? Is there other high-amp equipment in another room (water cooler, window air-conditioner, portable electric heater, etc.) pulling from this same circuit breaker.
  4. Is the circuit breaker not performing to specification? I've seen failing breakers trip early.
    First, check the owner's manual for power requirements. Next step, use no extension cord; and, insure nothing else is pulling power on that breaker. Then, use a different breaker and see if the problem follows the compressor. If all else checks out than I'd consider binding in the compressor causing the amp pull to be too high.
    Good Luck!
Mar 29, 2015 | Campbell Hausfeld Extreme Contractor...
Yeu sheng e209138 LB serie 7 amp
7 AMP MEAN CIRCIT WILL BE OPEN AT 7 AMP?
Aug 03, 2013 | Televison & Video
Need information on circuit breaker BR2100 60amp
Hi - I'm an electrician and can help you with your question.
A BR2100 circuit breaker is a 2 Pole 100 Amp (for the part number "BR2100", the "2" indicates the number of poles and the "100" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
A BR260 A BR2100 circuit breaker is a 2 Pole 60 Amp (the part number BR260, the "2" indicates the number of poles and the "60" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
It is not possible to have a BR2100 rated for 60 amps, 1 or 3 poles, or a BR260 rated for 100 amps, 1 or 3 poles.
It is not permissible to install any circuit breaker brand or type in any panel that does not specifically include it on a list of acceptable circuit breakers.
Circuit breakers are designed to carry 80% of the amperage rating.
To determine the load a circuit breaker can carry, multiply the circuit breaker amp rating by 80%.
This means that if you need to supply more than 80 amps, you cannot use a 100 amp circuit breaker. A higher rating is required. A BR2110 would be acceptable for loads greater than 80 amps, but less than 88 amps because the formula above says: 110 amp x 80% = 88 amps.
To determine the breaker size, determine the load (by measuring with a meter or obtaining amp rating of the load from the data plate) and multiply it by 125%. Using the same numbers in the example above; assume an 88 amp load. 88 amps x 125% = 110 amp circuit breaker. The 60 amp breaker is acceptable for up to 48 amps because 60amps x 80% = 48 amps. A 48 amp load needs a 60 amp breaker because 48 amps x 125% = 60 amps.
I hope this helps and good luck!
Jan 15, 2013 | Eaton Corporation BR2100 Circuit Breaker
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
Breakers support
When breaking Concrete, the breaker is expected to penetrate the material, allowing it to crack and shake loose from the reinforcing steel. High frequency breakers tend to provide better performance in this application as it is not the energy per blow, but the fast blow rate that destroys the concrete's structural integrity. We recommend on concrete walls, footings, and floors to use a 750 - 1,500-ft. lb. breaker. With larger projects, consisting of large footings greater then 4 cu. yards, use a 2,000 - 5,000-ft. lb. breaker. The high production demand of bridge and building demolition requires a 7,500 - 10,000-ft. lb. breaker.
Aug 27, 2008 | Northwest Smith Cooper 3/4" Hose End...
Breakers advice
When trenching, the breaker is expected to fracture a solid mass of rock into manageable pieces. The size of the material could be 100's of cu.yds, and the energy will be quickly absorbed. This is why it is recommended to work from a bench so the rock has somewhere to break out. We recommend when trenching in limestone or medium hard rock, to use a 3,000 - 5,000-ft. lb. breaker. When working in hard material we recommend a 7,500 - 10,000-ft.lb. breaker, and if high production is critical, a 13,500-ft.lb. breaker would be beneficial.
Aug 27, 2008 | Belle Group BHB30 - for 5 gallon Hydraulic...
Sport & Outdoor - Others Logo
60 people viewed this question
Top Gillette Sport & Outdoor - Others Experts
Are you a Gillette Sport and Outdoor - Other Expert? Answer questions, earn points and help others
