Question about Home
My alarm is chirping. I have turned the master electrical switch off, put new batteries in, twice, and disconnected the wires to the SOB, and it still chirps. Help, please.
  • 4 Answers
Check that power is actually coming into the wires with a meter. Clean out any dust. Also did you test the detector after replacing the battery? The chirping also can mean that the detector needs to be replaced.
Posted on Dec 06, 2016
Kidde smoke alarm chirping put new batteries in still chirping . Removed alarm and wires are chirping ,can't Believe it !!!! Has anyone else heard of this ?
It will chirp for up to an hour after the battery is replaced. Also make sure the "new" battery is ok, have gotten bad ones in the past several times.
Feb 24, 2017 | Home
My hard wired smoke alarm has had a new 9 volt battery installed and even a second new one installed and is still chirping 4 times every 30 seconds.
On many of the newer smoke alarm installations, all of the units are wired together so that if one goes off, it triggers all of the others so that no matter where you are you will definitely hear the maddening noise of the alarms! And if one of the other units has a bad or weak battery not only will it chirp but so will the others.
Only way around this is to cut any and all wires going to each smoke detector. They will still work because each has its own battery but there will be no more triggering of other units.
Oct 27, 2016 | Cars & Trucks
Alarm will not allow the engine to start
To manually disarm the alarm; open the door, turn the ignition on, press and release the valet switch. The alarm should chirp twice. Start the vehicle.
Aug 09, 2012 | Viper Vehicle Parts & Accessories
I have a 2005 Honda Odyssey Touring. I bought it used last year, so I am not too familiar with the car alarm in it. The alarm was fine until my battery died a few months ago. After the car was jumped, the...
Ok, try this.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
Dec 21, 2010 | Honda Vehicle Parts & Accessories
The battery was left off of my 02 ranger and now the anti theift is not working..I only have one key How can I reset the anti theift with one key???????????
Put the key in the ignition, and turn forward all the way just before cranking. Then within 5 seconds, locate, press and hold in the valet/overide button, found under the dash area, (push button, spring loaded) until the installed LED (the blinking light) in your dash area goes on solid, and the siren chirps once.
(Your valet switch might be the toggle (on/off) type. in this case, key on, flip switch in opposite direction, then turn the key off.)
This should reset the alarm, and reset the grounded relay on the starter wire, allowing you to start the engine.
At this point, the only thing working would be the keyless entry from the alarm, if it came equipped that way.
Just Repeat these steps to place it back to usable armed mode. You may get 2 chirps, confirming it, and the lights may flash twice as well.
That should do it.
Dec 11, 2010 | Ford Ranger Cars & Trucks
I had to change the battery. After replacing the new battery all systems work, but the car won't turn over and the factory alarm is blaring. How do I disable the factory alarm? I do not have the...
If you have the Toyota factory alarm, there should be button under the driver's side dash to reset the alarm....Look for it 1st, then read below.
all the way just before cranking, to the ON position.
GL,
Td
Aug 10, 2010 | 1997 Toyota Camry
I removed the battery from my car and when i put it back in the car would start all the control panels work in the car I just wonderd if i had to reset the alarm with the fob
Open the boot lid and drivers door, and switch on the ignition. Rock the valet switch, in the centre console, 5 times. The system will chirp to indicate it has entered learning mode.
On models with seat/mirror/steering wheel memory functions, the first remote will be linked to memory 1, second to memory 2 etc.
Press the larger, lock, button of the remote. The system will chirp to confirm it has got the signal. If it doesn't receive any signals for 15 seconds, it will chirp twice and exit learn mode.
To reset remote, rock the valet switch once. The system will chirp twice for remote number two, three times for number three etc, then press the lock button of the remote as above.
When finish, wait 15 seconds for the system to time out and chirp twice, turn off the ignition, close the doors and boot lid and the job is done!
Feb 28, 2010 | 1993 Jaguar XJ6
Replaced 9 v batteries, units still chirping
This is the troubleshooting information from the kddie site. The problem is usually related to an older battery or improperly installed battery. You might also have to do a reset as described below. If battery and cleaning don't work, it might be time for a replacement - short money to keep you and your home safe.
  1. The battery may be loose, or improperly installed.
    Verify that a battery of the recommended type is securely installed. Make sure to use a battery with a use-by date no later than four to five years in the future. Check that the battery is snapped in completely so it cannot be shaken loose. It’s possible that battery connections may not be making good contact with the battery. Disconnecting and re-connecting the battery once or twice will likely fix this condition. On units with a front-load battery, be sure that the battery compartment door is closed completely as well. Loose white neutral wire can cause an echoing chirp. (From one unit to the next)
  2. The smoke alarm sensing chamber may be dirty.
    Dust and insects can collect in the sensing chamber of the alarm. An accumulation of dust in the sensing chamber can cause the unit to chirp. It is good practice to clean the smoke alarm when you change the battery. Static electricity from the ac quick connector attracts dust and can cause false alarms.
    Cleaning smoke alarms:
    To clean your alarm, remove it from the mounting bracket as outlined here. You can clean the interior of your alarm (sensing chamber) by using compressed air or a vacuum cleaner hose and blowing or vacuuming through the openings around the perimeter of the alarm. The outside of the alarm can be wiped with a damp cloth. After cleaning, reinstall your alarm, verify the green LED is on and test your alarm by using the Test Button. If cleaning does not restore the alarm to normal operation, the alarm should be replaced.
  3. Check environmental conditions:
    • Humidity, steam and condensation can cause false alarms. Causes of condensation are:
      • Extreme temperatures changes.
      • High ambient humidity.
      • Unit being installed in an uninsulated electrical box mounted on a ceiling beneath an attic. If this condition exists you’ll want to move the alarm. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check to see if there is a cooling/heating register, a ceiling fan or an open window within 3 feet of the alarm. If there is, move the alarm away from the source of the increased airflow. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check the temperature of the room. Smoke alarms operate at 40 degrees to 95 degrees Fahrenheit. Carbon monoxide alarms operate at 40 degrees to 100 degrees Fahrenheit.
  4. Reset the alarm.
    Some current model smoke alarms have a processor that retains certain error conditions, such as a weak battery. The error condition should reset when the battery is replaced but sometimes it does not and must be manually reset to clear the error.
    To reset an AC unit with a battery backup:
    Turn off the power to the smoke alarm at the circuit breaker.Remove the smoke alarm from the mounting bracket and disconnect the power. Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reconnect the power and reinstall the battery. The unit will chirp once when the power is restored and should not chirp afterwards.
    To reset a DC only unit:
    Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reinstall the battery. The unit will chirp when the battery is first connected but should not chirp afterwards.
  5. An electrical condition may be causing the power to the unit to be interrupted.
    If the AC power to the unit is interrupted, the unit will chirp when the power is restored. This could be caused by power surges.
    If the chirping seems to occur at about the same time in the evening or morning, it could be due to a surge created when the power company switches electrical grids to meet demand. Check to see if the chirp (or chirping) occurs when something else in the house is turned on such as an exhaust or attic fan, a heater, etc. If the smoke alarm is connected to a circuit with such a device, the alarm may chirp when the other device is switched on. If this is the case and the device is plugged into a wall outlet, move it to another outlet on a different circuit. If it is a hardwired device, have an electrician investigate it. These conditions can be minimized by installing your alarms on a dedicated circuit in compliance with NFPA requirements.
  6. Replace the alarm.
    If none of these conditions exist and the suggestions don't alleviate the symptom, the alarm should be replaced. Age may be a factor. Smoke and heat alarms should be replaced every 10 years, and carbon monoxide and combination alarms should be replaced every 7 years. Most of our alarms have a 5 year warranty from date of purchase (check your user manual for details). A date code is stamped on the label attached to the back of the unit.
Feb 02, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home Logo
147 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
