My tv skips channels or I get a message that there is no signal. the same channels work on other tvs in my house
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
SOURCE: Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Posted on Oct 05, 2008
SOURCE: RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Posted on Aug 12, 2009
  • 635 Answers
SOURCE: New LG 32LD350 - Allowed TV to auto-program
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Posted on Mar 11, 2011
  • 174 Answers
SOURCE: hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Posted on Jul 23, 2012
Can't get channel 29 to come up. Tv worked fine, then now it skips to the next channel.
Go to your TV settings and manually add the channel. Sometimes if TVs don't detect a signal from that station it Auto deletes that space
May 11, 2017 | Televison & Video
Hi, We have a Panasonic Viera Plasma TV. The TV was on when all of a sudden we heard a few clicking noises and then the picture was lost and a 'no signal' message was displayed. We tried other channels...
It sounds like you have taken the steps to isolate the problem to the TV. it seems to be a bad tuner on the Main board. The no signal displayed indicates the TV is otherwise okay. If you have a DVD player or other source you can connect, and you get a picture, then your TV has a bad tuner for sure.
Feb 21, 2015 | Panasonic Televison & Video
How to tune a tv channel
This could be too much signal.
Just to be sure though, try the set in another room where one of the other TVs works okay. This will help you see if it's a cable or a TV signal issue. If you pick up all the channels okay it's likely that that other TV point has some bigger signal losses due to the cabling.
The mux (transmitter channel) carrying the BBC signals will be amongst the strongest at each and every TV transmitter across the land. This is because the BBC and the main ITV channels have to reach about 96% of the mainland UK population in order to the broadcasters to fulfill their remit.
TV tuner sensitivity varies between brands and models. It may be that your old TV was just about okay with the signal power, but the new TV's tuner is over saturated.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 06, 2014 | Televison & Video
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
37" LG flat screen is
With the onset of more and more TVs being hooked up to cable, TV manufacturers didn't need to make the tuners as sensitive because the signal from the Cable Co. was much stronger than the over the air signal. If the other TVs are older they may be just sensitive enough to lock onto the channel signals. You could ask your cable provider to check your available signal in the house to see if there is the proper amount of signal. Some channels can inherently be stronger and when "block converted" (put where the cable company wants the channels) all come thru but some are a bit clearer.
Aug 28, 2011 | LG 42LG30 42 in. LCD HDTV
When I switch the TV on I just get a message 'No Signal' ,this also happens when I try to play a DVD. The TV is on and I just get a blue blank screen. The other TVs in the house that are all...
You might be on the wrong "channel" on your TV. On the remote for your TV, there should be a set of buttons for if you want the remote to control the TV, or DVD player, or Aux 1 or 2. You want to click the TV button and try changing the TV's "channel". Your cable/DVD player are on different "channels" of the TV. Try scrolling up and down through the "channels" of your TV.
May 25, 2011 | Bush 5693D 24" TV
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? ( has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
