How do I fix Panasonic error code f30 - Washing Machines
2 Suggested Answers
duby1990
  • 370 Answers
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Posted on Nov 19, 2008
Error Code E30
Hello tcavness609 - Are you certain the error code is F30? This manufacturer does not have a F30 error code for any washer. However, there is an error code F31 that indicates that the pressure senor is not communicating with the main control board. A professional will need to inspect the wiring between both parts and depending on the diagnoses either part will need replacing.
Dec 18, 2012 | Frigidaire Affinity ATF7000E Front Load...
Wont do anything getting F30 error code
Do you mean F03? that error is known in Panasonic video products. It usually applies to the VCR, which means a mechanical fault; such as loading motor and/or mode switch. The switch itself would be on the main board under the VHS deck, and can be cleaned with special electronic spray cleaner, and electronic lubricant (after the cleaner), but for more reliable results, the mode switch may require replacement, which should be done by a workshop. If this is the only issue you have with your combo unit, it shouldn't cost too much to correct this problem. Either try cleaning the switch yourself (being careful when opening unit), or submit to workshop for quote and professional repair.
I have never heard of F30 as a video/DVD error code before. That error applies to some Panasonic air-conditioners and is a system error.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Whirlpool WFW9200SQA10 Front Load Washer displays F30 code. What does F30 mean? Thanks
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 20, 2010 | Whirlpool WFW9200S Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jan 16, 2010 | Kitchen Ranges
Kenmore HE2 Plus 110.47512600 Error Code F30 = Dispenser System Error. Have reset CCU multiple times. When cycle starts, dispenser motor runs for 3 minutes (~11 revolutions) then stops with F30 error
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2009 | Kenmore HE2 Plus Front Load Washer
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
