Question about Senco Air Tools & Compressors
I have a senco profinish 35 and it shooting the nail down through the air gab hole it looks like the gun is not letting the nail set at the right angle
  • 1388 Answers
SOURCE: porter cable roofing gun
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or enjoy
Posted on Dec 07, 2008
  • 1388 Answers
SOURCE: Senco SFN1 wont work
I have worked on many sfn1 with the problem that you describe. Here are a few things to check. Driver/piston too tight or too loose in cylinder or bent. It should be relatively easy to move the driver piston up/down the cylinder. Usually it should hold it's own weight and not drop down the cylinder. There is a washer that should be at the bottom of the gun under the bumper (washer part# bf0070). This washer must not be worn to the point that too much air will leak past or missing. Finally there is an oring that controlls return of piston (part # lb0077). Pull out the cylinder and find it located on the outer part of the cylinder close to bottom. Clean the port holes under the oring and make sure that the oring fits snuggly. Do not use oil in this gun. Oil will swell the rubber parts. I use silicone lube available form Lowes in the plumbing department. The grease is used to lube faucet orings. Good luck with your repair and email if you have questions.
Posted on Mar 16, 2009
  • 65 Answers
SOURCE: air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Posted on Mar 24, 2009
  • 21 Answers
SOURCE: Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Posted on Feb 14, 2010
  • 1388 Answers
SOURCE: I have seen many nails that supposedly fit the
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Posted on Mar 27, 2011
I can't shoot nails on my senco finish pro 35
Make sure you have the right nails and enough air pressure
Nov 18, 2017 | Senco Tools & Hardware - Others
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
Feb 16, 2017 | Senco Air Tools & Compressors
Senco Framepro 602 has air coming from the top of the gun when the trigger is pulled and will not shoot the nails.
Sounds like the bar that slides down to push the nail is jamed you should disconect it from the air and check to make sure a nail is not stuck you should be able to look at the gun and see how to disasemble it in the front end to release it once that is done try some white grease on the part befor you reasemble it
Nov 20, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Framepro 602 only shoots air out a hole in the top when the trigger is pulled, occasionally shoots a nail but more often just shoots air
You have some worn out o-rings in your gun. Get a Senco repair kit #YK0360, use everything in the kit and your gun will be as good as new. Type "senco yk0360" in your search engine and shop around, the kit should be around $45 - $50.
Oct 11, 2010 | Senco Air Tools & Compressors
How to load nails into the magazine
Hi. Here are pix that show u what to do.
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Jul 12, 2010 | Senco FinishPro 35 FinishPro 15 SLS15 3...
My 20 ga stanley bostich air stapler stopped firing the staple all the way in. Any ideas?
Do you have an adj pressure gauge? Take it off, you don't need it for nail guns, Only for painting. Guns run on a full tank, wide open, 120 lbs pressure. If that doesn't set your nail, either the safety is holding you off your work and not letting the staple seat or the gun needs to be rebuilt. Check the drive pin and make sure it didn't break the tip off. Sometimes I wish mine wouldn't set the nails all the way, because some materials, it goes right through. You have to hold it off manually. Also, depending on material, some guns do not have the power to drive into Oak. Only the Senco has the power to do that. we tried every gun made and found it to be the best. Got rid of all the other guns and kept a complete line of Senco guns in our shop. Hope this helps.
Jun 17, 2010 | Garden
Clean the track and piston by removing nail tray (there are a couple of allen screws)and removing the gunk from the nail tape and if you have been shooting something glued that to. Remove head assembly and thoroughly clean and oil that also. that should fix you right up I have a couple of these guns and that is typical.
If that is no the problem rebuild the gun it is worth it as they are a great air gun
Hope this helped
Dec 15, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
How to unload nails from Senco FinishPro 35
when you pull the spring back like your going to load it .put your finger in the hole and push it .you'll see that the nails will be release.
Mar 28, 2009 | Senco Finishpro 15 Finish Nailer & Sls15...
Air Tools & Compressors Logo
125 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
