Question about Sewing Machines
I need bobbin case for Shark model 612C sewing machine
  • Sewing Machines Master
  • 11,474 Answers
Search for:
Make Model replacement parts
contact manufacturer support.
Posted on Dec 06, 2016
Where can i find a bobbin case for a shark euro pro model 71132L
Ellen did you try putting the name and model no in to a search? Also, try going on the Shark site and put in Euro Pro, etc. I have a EuroPro Crafter's Choice and sure enough I found what I was looking for. Try it. Hope that helps.
Nov 21, 2014 | Euro-Pro Shark Sewing Machine
612c gps
There is a user's manual available on the Singer Site (singerco) for a W612 that may be your machine. Assuming that it is, It is actually an older White machine.
Once inserted into the case, the bobbin will not come out when the lever in the center is raised. Insert the bobbin into the case--GENERALLY it unwinds counterclockwise on those machines, but if you have a problem sewing, trying reversing that. There is a slot on the left side of the case that the thread goes through, and an assembly above the slot that the thread must come out, so that tension is exerted on the thread, and it comes out close to the top projection. Insert the bobbin by raising the center lever and using it to put into the machine, with the projection part at the top.
Jul 01, 2014 | Singer Sewing Machines
Bobbin case for 4423 singer keeps coming loose
it would be a good idea to have the sewing machine checked to see why the bobbin case is loose.
here is a link for parts for the sewing machine
Aug 05, 2013 | Euro-Pro Shark 60 - 384
My bobbin casing keeps jumping loose
it would be a good idea to have the sewing machine checked to see if there is something wrong with the hook and hook race that hold the bobbin casing.. you may need a new bobbin casing.
Shark model 361 when drawing up the bobbin thread it wont catch upper thread wandering what the bobbin looks like for this machine
try changing the needle
rethread the machine top & bobbin
check with to see if they show a picture of the bobbins for that machine
May 27, 2012 | Euro-Pro Sewing Machines
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
Sharlk sewing machine
the needle keeps breaking it is hitting the bobbin case .
Dec 31, 2007 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
