Question about Kitchen Ranges
No error code on intex pure spa but beeps about every five minutes
Seems to otherwise work fine but continuous beeping is very annoying and stopping us using it!
  • 473 Answers
SOURCE: F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Posted on Nov 09, 2007
SOURCE: Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Posted on Nov 04, 2009
SOURCE: buttons dont work on danby microwave
I had the same problem, but only with 4 buttons. The 3,6,9 & Start/Stop button stopped working.
Hard reset & leaving unplugged did not work. Eventually, I tried picking it up and dropping it from several inches, and smacking it on the side. That did the trick. Works great now!
Posted on Apr 25, 2010
  • 2605 Answers
SOURCE: The cycle signal beeps continuously and Error 68
Welcome to FixYa.
The E68 is indicating a push button is stuck, refer to this chart below for explanation and potential remedy.
The reason this is happening can be for a couple of reasons. When a button is pushed, the contact inside the control is sticking in the "closed" position, or the plastic button which activates the switch, is binding on the console and not allowed to return via the small spring which insures it does under normal conditions.
To investigate further the console would need to be serviced/torn-down. I'd try the suggested test program first though, i.e.
If you think this is something you can perform let me know and I'll try to assist you in that manner. If the print here is too small to be clear, if you post an email address I can send you the test program and error clear mode, it's up to you.
Let me know how you make out or if anything is not clear and I'll help in whatever manner I can going forward. Good luck.
Macmarkus :)
Posted on Mar 06, 2011
Testimonial: "Can you send the process in a larger font?? Thanks"
  • 963 Answers
SOURCE: Began to beep in intervals.
Why is my Powerbolt 1000 unit beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Posted on Sep 23, 2011
Makes random beeping noises all hours of the day & night. Annoying but wondering if something is wrong or if there is something we can do to stop it? Works fine otherwise!
I have never heard of that happening before. I think you need to ask Kitchenaid direct. Once the machine is off and dead, it should stay quiet until you press a button or open the door.
Help Contact Us KitchenAid
Mar 28, 2016 | KitchenAid KHMS2056SSS Microwave Oven
I have an LG e522b. Came home to it beeping after holidays. Left it off for a week. Continues beeps when powering on. Temp cont flashes on freezer. But otherwise fridge works still. Beep stops when...
It would seem that a bad sensor somewhere is causing this malfunction. So check all the sensors including thermostat, temperature and door sensors cheers
Feb 04, 2015 | LG Refrigerators
I have an "Intex Pure Spa" inflatable spa. It shut itself off. when I push restart it starts up then in about 10 sec an "E" comes up on the screen and it beeps. What can I do to reset and fix the err
Has your problem been resolved?
Please use 'Comment', and inform the forum here of your experience.
What did you do? Did Intex help?
If you are still dealing with this problem, let us know.
If so, and for anyone else with a problem ...
Support Intex
Jan 30, 2015 | Intex Pool & Spa
Error code 04?
There is no error code 4
The unit is probably set at 4 hours operation.
To change it turn unit off then back on
Now press and hold up arrow ti'll the unit beeps
now press and hold down arrow ti'll unit beeps again
Now either quickly press the up arrow or down arrow until you get the hours of operation you desire
once you have the hours flashing simply re-peat the long holding of the up arrow ti'll it beeps and down again ti'll it beeps once the beep then the # will quit flashing wait 10 minutes or so for chlorine generator to start
Jun 17, 2011 | Intex Automatic Salt Water System for ...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
