Question about Miscellaneous
What causes earthquakes - Miscellaneous
How are earthquakes made?
The earth's crust which is 3 to 45 miles deep is in sections called tectonic plates. These slide againt one another. When they slide, they sometimes snag against each other. That entanglement even cracks the crust. All movement does not create earthquakes. It depends on the direction of the movement and the strength of the movement.
Nov 15, 2017 | Garden
What causes an earthquake
google - earthquakes and causes---- and you will get good vocabulary and photos and diagrams
Aug 08, 2017 | Cars & Trucks
An earthquake is caused by a strong movement along a.....
... along a SEGMENT OF EARTH ... thus, it's called an EARTHquake.
May 15, 2017 | Health & Beauty
What are the effects of earthquakes
Although probably the most important, direct shaking effects are not the only hazard associated with earthquakes, other effects such as landslides, liquefaction, and tsunamis have also played important part in destruction produced by earthquakes.
Earthquake Effects
eqseis.geosc.psu.edu/~cammon/HTML/Classes/IntroQuakes/.../earthquake_effects.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=What+are+the+effects+of+earthquakes
Dec 02, 2016 | Garden
Whats a transform buondary
Hi Michael:
I'm thinking you might be asking about tectonic plates.
When they slide past each other earthquakes are caused.
Here's a link that gives more information.
https://www.google.ca/#q=tectonic+plates+map
Hope this helps you.
Cheers
Jan 26, 2016 | Garden
How does an earthquake alarm work?
An earthquake alarm provides an early warning by detecting an earthquake's soundwaves before the shear wave hits your area. The alarm will detect a quake that is even many miles away! A loud alarm will then go off.
May 07, 2013 | Home
Causes of Tsunami
Tsunami is a Japanese word meaning ''huge wave'' that refers to a series of large ocean waves. It is caused basically due to underwater earthquake, Richter magnitude exceeding 7.5 to produce a destructive tsunami.
Concept can be summarized as follow:
The earth is constantly moving on large tectonic plates. When these tectonic plates moves past each other, collide and/or slide under one another an earthquake results. This is what happened with the recent tsunami that devastated Southern Asia. A massive earthquake in the Indian Ocean measuring 10.0 on the Richter scale jolted the seabed causing the sudden displacement of a very large volume of water. The earthquake temporarily produces a fluctuation in the mean sea level of a specified area. Waves quickly form as the displaced water tries to recapture equilibrium by filling the vacuum that was created. Tsunamis are a series of extremely long waves that are created after a large volume of water is displaced. The amount displaced must be significant enough to create waves underwater in the vast ocean. Waves are formed as the displaced water mass moves under the influence of gravity to regain its equilibrium. The larger the displacement, the larger the wave generated.
May 03, 2010 | Yosemite Technologies TapeWare 7.0...
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
