Question about Apple iPod Audio Players & Recorders
My password to iTunes doesn't work on my iPod when i try to fix it but it works on different device?
  • 57 Answers
SOURCE: Why my iPod doesn?t appear in iTunes?
Laptop or portable connecting via USB? "See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh with a Windows PC. To see which platform your iPod is formatted for, follow these instructions. Your iPod isn't connected to a high-power USB port If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer (not a low-power one such as the USB port on your keyboard or bus-powered USB hub). Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer (or to a self-powered USB 2.0 hub that's connected to a high-power USB 2.0 port on your computer) if the computer still doesn't recognize your iPod. Alternatively, if your computer has a FireWire connection, try using that instead. If you're connecting an iPod, iPod mini, or iPod shuffle to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. You're not using a WHQL-certified IEEE 1394 card If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod. If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this: Go to the Windows Hardware Compatibility List website. Enter All Products in the ""Search for"" field. From the Product Categories pop-up menu, choose 1394 Controller. Click the Search Now button. Note: Windows XP information is not listed on the initial search screen, but is listed when you click on an individual card. You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP. (Apple sells FireWire cards that are compatible with iPod at the Apple Store.) To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it. Your connections aren't secure Make sure that there i
Posted on Sep 28, 2005
  • 59 Answers
SOURCE: itunes locks up when i connect my ipod touch
try to install itunes again
Posted on May 15, 2009
  • 89 Answers
SOURCE: ipod touch frozen restart help!
have you tryed a manual restar to do this you need to hold power and the home button at the same time for at least 10 sec or till the ipod resets hope this helps
Posted on Jul 30, 2009
SOURCE: My ipod touch just shows the screen with the usb
  1. Disconnect the USB
  2. Turn off the iPod
  3. Press and hold the Home button and reconnect the USB
iTunes should start up and show you that there is an iPod that needs recovery. It can perform the recovery for you, but it will reset the iPod to factory settings deleting whatever you have on it.
Posted on Sep 01, 2009
anujtaluka
  • 392 Answers
SOURCE: ipod locked won't recognize in itunes
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
But you will lose all your data
Posted on Sep 19, 2009
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
I dont know what to do to my Ipod on itunes all it keeps saying is connect to itunes what do i do
Is the Ipod on when you connect it? If so, reset it and connect it again. If that doesn't work, check that the cord you are using isn't broken or your Ipod's jack isn't messed up. If it still doesn't work try a different usb slot on your computer.
Jun 07, 2012 | Apple iPod touch
How do i connect my ipod touch to itunes?
Plug in your ipod to the computer, and iTunes should recognize the iPod. If this doesn't work, try a different cable or USB port.
Apr 24, 2011 | Apple iTunes
Ipod lock
put the ipod in disk mode and see if it comes up on itunes.
Press and Hold the Menu and Center Buttons until the ipod apple logo come on the screen. The quickly switch your fingers to the Play/Pause and Center Buttons and hold until a check mark appears on the screen. Connect to iTunes and restore
If this doesn;t work let me know i can help you try something else
Jun 02, 2009 | Apple iPod nano
I have an apple Nano(2G). Running software 3.1.1 Itunes is 8.1. When I plug it in yy computer and device manager recognizes the device but itunes does not recognize the IPOD when i plug it in.
Here is a trick I have tried and it worked.
in My Computer Right Click your Ipod device and explore the memory.
in the device software choose a file and right click and open with iTunes.
if your itunes is running it should try and open in itunes.
If it doesn;t work,
Try another USB port preferrably a USB 2.0 port.
Good Luck
May 06, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod wont show up on itunes
Try the five r's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
Center button on my nano wont work
Most likely needs replacing, but you can try the "soft fixes":
Do the 5 R's:
installed.
May 04, 2008 | Apple iPod nano
Ipod not recognised in itunes
You should try connecting the iPod to a different computer and see if it works. If it doesn't work, you should try connecting with a different USB cable if you can get a hold of one. One of the two should be your problem (a defective USB port on the computer or a defective iPod USB cable).
Dec 28, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod not recognized by computer or itunes
I struggled with this issue for a while and finally found a post that helped me. Hold menu and the center buttons until the iPod turns off. Then, immediately hold the left and center buttons to pull up the iPod diagnostic menu. Scroll down to the option "Reset" and select it. My iPod was finally recognized by iTunes. Good luck :)
Nov 20, 2007 | Apple iPod nano
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
