Rti remote docking station does not seem to properly charge the battery
sparky1500
  • 1066 Answers
SOURCE: Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
Posted on May 17, 2008
gisvc
  • 40 Answers
SOURCE: when charging the wii remote should the docking
HI,
THE DOCKING STATION SHOULD INDICATE BLUE WHEN CHARGING AND GREEN WHEN FULLY CHARGED IF IT SHOWS RED IT IS INDICATING A FAILURE IN THE REMOTE TO MAKE AMPLE CONTACT DUE TO SOME HARDWARE PROBLEM. YOU MAY CONTACT THE SERVICE CENTER IN YOUR MANUAL FOR REPLACEMENT IF STILL UNDER WARRENTY OR YOUR NEAREST RETAIL STORE IF NOT UNDER WARRANTY.
HOPE THIS HELPS THANKS!
Posted on Mar 30, 2009
cjackHD
  • 71 Answers
SOURCE: does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
Posted on Jun 01, 2009
SOURCE: Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Posted on Jun 20, 2009
SOURCE: new ipod won't charge on bose docking station
I have been looking for sometime and have finally found a 3rd party power converter. Another solution is to send your docking station to Bose and for $99.00 they will repin the dock so charging will work. The converter and adapter only cost about $30.00. Here is the link to the site I ordered from. I just ordered it so I am not abot to confirm functionality yet.....
http://www.griffintechnology.com/products/firewire-to-usb-converter
Posted on Oct 16, 2009
Remote in not charging; just blinking
If the remote is over 4 years old it's most likely the battery. Just need a replacement.
Jun 08, 2014 | Rti Technologies Rti T1 Remote Control
I haven't played my wii in a while and have just plugged it all in and my controllers are not working. They don't seem to be charging in the docking station, their individual docks are not lighting up...
Yes they should light up blue when they are charging.
Double check and make sure your docking station is still plugged in and turned on.
Most Docking stations are third party accessories, meaning, they were not manufactured by Nintendo. Some of them do not work very well.
If all else fails, remove the rechargeable battery pack from the Wii Remote and put regular AA batteries inside of it. The Wii Remote should work just fine.
Personally, I prefer to use rechargeable AA batteries rather than charging packs or docking stations. The charge packs/docking stations just never seem to work as well as they're supposed to. The rechargeable AA's work great and they're much more versatile since they're not limited to use in the Wii.
Apr 02, 2011 | Nintendo Wii Console
My 1 year old RTI T2+ suddenly will not charge. I've tried charging it on 2 separate charging stations with no luck!
Try replacing the battery. If this does not fix the problem the charging circuit may be bad and need service. Go through your dealer if you purchased it that way and they may be able to provide you with a loaner while it's sent off to service. Or call RTI yourself and setup a service request. (952) 253-3136
Feb 06, 2010 | Rti Technologies Rti T1 Remote Control
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
The remote will not hold a charge, we have only had it for @ 6 months. The blue light on the charger stays on, but the remote does not light up when you push the buttons
You may have a bad battery, try testing a new battery and try again. If this does not fix the problem the remote and possibly the dock may need to go to service. Call your dealer about getting a loaner while it's off to service or if you purchased this some other way call RTI and set up a service call with them. (952) 253-3136
Jan 15, 2010 | Rti Technologies Rti T1 Remote Control
Wii docking station
try new (non chargeable) battery's and if they work then you have bad battery's, if they dont you have a problem with the remote or unit.
Jan 07, 2008 | Nintendo Wii Console
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
