Question about Sony PSP (Piano Black)
My psp doesnt start at all!!!!
I am using 3.71m33 cfw.{{ in order to upload some xmb themes onto my psp }},(1) i went to recovery mode (2)advanced settings(3)toggle to flash 0 and enable(4)connected it to pc,there were some five folders in it (5)now the file which i had downloaded (regarding xmb themes) had three folders whose names were same as three out of five folders which were already in my psp( flash 0 files) (6)now i copied those three folders in the psp(flsh 0 files), as it already had three folders of the same name, i selected "yes to all" when i copied them (7)copying the files was over and selected "exit" from the recovery mode (8) my psp did not start ...
THE THING IS WHEN I STAR MY PSP THE GREEN LIGHT GLOWS FOR SOME SECONDS BUT THE PSP DOESNT START
i tried everything ..taking out the battery ...using only charger...still it didnt start
PLEASE PLEASE PLEASE HELP ME OUT , I CANT AFFORD TO BUY A SECOND PSP WHILE I CANT LIVE WITHOUT IT TOO
    Sergeant:
  • 321 Answers
Dude dont ever mess with the flash files ever!!!!! you have to reinstall ur custom firmware!
if you have a psp pandora battery then all you need to do is go tho this and rad five comments.
http://forums.afterdawn.com/thread_view.cfm/688507
then using psp pandora deluxe go to recoverry mode and put the psp in usb mode! then psp pandora deluxe will have a option to put in into a drive. chose the drive ofr ur psp the inject all the files!
psp pandora deluxe needs net frame work 2.0 to wokr so google that and install it. then install psp pandora deluxe! then you will need to go online and the 1.50 files and the 4.01! then follow the websites instrutions!
Posted on Jul 20, 2009
I accedentally delete files on flash 0,then my psp suddenly turned off and poof!!!!! i can't acces everything on it.i turned it on but it was just a green light(power LED indicator).help!!!
1st your get a 1 gig memory stick and an a extra battery, then you make the battery a pandora, either by hard modding it or buying a low volt pandora from internet. then you download a file onto your psp memory stick google "magic memory stick" it should contain a new firmware either custom or ofw. then you put your pandora battery in the psp with the mem stick, then turn on the psp while holding one of the recovery buttons on my psp 1001 its the right bumper. hold that till you get the recovery menu then you should see an option that says "Install Custom firmware" or "Install Original Firmware" select the one you want, then bam your flashed files that are needed to run your psp is back on your flash 0, plus if you wanna download free psp games and roms your able to run them on your new modded psp but you have to select CFW in order to run mods.
Jul 23, 2011 | Sony PlayStation Portable (PSP) Console
Tip
"Hack your PSP" guide
1.)Here are some termins i will use:
OFW-Original firmware,this is your system software
CFW-Custom Firmware,Modified firmware
HEN-Homebrew(home-made)enabler,this is much like a CFW without some features and its not permanent this means its gone after a hard reboot(taking out the battery or completly shutting down the system)
XMB-CrossMediaBar your PSP menus
PANDORA battery-a modified battery that allows you to put your PSP in service mode and do wathever you want with it its used for unbricking,downgrading and installing CFW.
BRICK-Its when you mess with your system software and damage it,its called flashing,its called a BRICK since your PSP becomes useless as a brick.
2.)PSP 1000 (FAT/PHAT)
This is wath it looks like:
ANY PSP 1000 is hackble
Ways of hacking:
1.You can use a Pandora Battery that you have to buy
*how to use a Pandora Battery:after you buy a Pandora and a MMS(Magic Memory Stick) insert them in your PSP and you shoud see a menu with CFW you have on your MMS.
2.)CFW or HENs depending on your firmware you can use CFW or HEN without pandora.
PSP 2000 with non V3 MOTHERBOARDS:SAME as PSP 1000
PSP 2000v3/3000/Go:
maxim615_2.jpg3000
maxim615_3.jpgGo
1.)On the 2000 and 03g 3000 you can have LightCFW or HEN
on 4g 3000 and GO you can have only HENs
CFWs:5.03 GEN,6.35 PRO-B,5.50 GEN
HENs:6.20 TN HEN
LINKS: http://www.psp-hacks.com/file/2052 6.35 PRO-B
http://www.psp-hacks.com/file/2046 6.20 TN-C
http://www.psp-hacks.com/2009/12/15/psp-custom-firmware-5-50-gen-d3-and-5-03-gen-c-for-hen-released/ 5.50 and 5.03 GEN
on Mar 01, 2011 | Video Game Consoles & Games
Tip
How to hack a psp without pandora ?
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00.
Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer)
Steps to install CFW on a PSP Slim without a Pandora battery.
1. Check and triple check you have a hackable PSP that will accept
custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP.
Run the installer and point it to your Memory stick Pro Duo root.
2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo.
3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post.
4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6
Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
visit www.newzgadgets.co.nr
on Mar 10, 2010 | Video Game Consoles & Games
Auto shut off psp 1000
Be more specific
Go to Power save settings
Change Auto sleep to OFF
If not,then i thing your PSP Panel is malfunctioning. formatting your psp with your a PANDORA Battery it will format
Flash 0
Flash 1
Flash 2
Flash 3
or enter the recovery mode on the psp and Format flash 1
Nov 12, 2009 | Sony PlayStation Portable (PSP) Console
Tip
Pandora's Ultimate Magic Stick 3.80M33-5
New version of UPMSv3 - universal PSP Unbricker/Downgrader/Upgrader, also known as Pandora's Ultimate Magic Stick, Now work with DC ver4 (Dark_AleX’s), for installing CFw 3.80M33-5 and creating memory stick into a “Ultimate Magic Stick” for use with “Pandora’s battery” (jigkick). Works for both PSP, Slim and/or Fat, and 1 stick for all functions for Unbricker/Downgrader tools. Also available is the “UPMS_v3.pdf Guide” to help you get started and usage.
The Ultimate Pandora’s Magic Stick is the simple solution to easily accomplish any of the following:
  • Recover any bricked PSP (Fat or Slim) and install sony firmware or CFw M33.
  • Upgrade Fat-Slims PSP to CFw 3.80M33-5, with 1.50 kernel patch-Fat Only.
  • Upgrade Fat-Slims PSP to CFw 3.71 M33-2, with 1.50 kernel patch-2 -Fat Only.
  • Update to 3.71M33-4 are installed to the ‘GAME’ folder from the XMB.
  • Downgrade Fat PSP to Fw 1.50.
  • Upgrade Fat PSP straight to CFw 3.52M33 from Extended Boot Menu then install update 3.52 M33-4 from XMB, without need to downgrade to 1.50.
  • Boot up PSP using Ultimate Loader with support for choosing which Pandora’s you reach V1, V3 or V4.
  • Boot up PSP to XMB with UPMS inserted-Fat Only.
  • Boot up to a full FW 1.50 from Memory Stick-Fat Only.
  • Use PSP Filer and other tools (If it requires 1.50, can’t for Slims).
Note: This software is free, and comes with no warranty. Despite it has been tested and it has worked, there is some risk with any PSP operation that involves flashing, so please try this at your own risk!.
Only Memory Stick "Pro Duo" are compatible. Memory Stick Duo are not supported. Read more... for installation
here.!
on Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
Tip
PSP Firmware 3.71M33-2 Diagram installation.
This article will explain a diagram of PSP CFw 3.71 installation. I have provided this document as a guide to helps PSP Users get started for installation CFw 3.71M33-2 with 1.50 kernel Addon2 on both PSP, Fat and Slims. here's a simple steps to find out.
Q:How do I know what version of the firmware I have?
A:Follow this, <b>Version check :</b> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP.
Q:How do I boot into "Recovery Mode",?
A:Do a full turn off (hold power button >5sec) and hold the "R-trigger" while turn on the psp.
Q:How do I know what kernel of game folder configured.?
A:Do this via "Recovery Mode" >> "Configuration" >> "game folder homebrew (currently: 3.xx kernel)"
Q:How do I activated the plugin No-UMD of CFw M33.?
A:Do this via "Recovery Mode" >> "Configuration" >> "UMD Mode" >> Select currently : "M33 Driver - No UMD". Any 4 option umd mode you can select, we recommended to select "Sony NP9660" for most games compatibles.
Q:I getting a blank screen/BSOD when booting my PSP, after downgrading my psp with pandora's?
A:Press "Bright" button on PSP, You will get a message for telling You to press "Circle" (O). Do it, and reenter your settings. Reboot your PSP if necessary.
Source : http://e-arena.blogspot.com/2007/11/psp-firmware-371m33-2-diagram.html
Hopefully this helps..!
on Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
I need help
To use the .CTF Themes you need to download the plugin called cxmb.prx
1. Download the plugin (cxmb.prx)
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
To Use the .PTF Themes download it first then put it inside ms:/PSP/THEME. if the folder is not there please create it. To apply the theme on your PSP, go to “Settings” => “Theme Settings” => “Theme”.
Oct 24, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP Theme Help
Make a theme folder called
THEME
all caps
put it in the PSP folder, so the outcome will be
PSP/THEME
Feb 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
208 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
