I need the circuit board for the hef26 electric fireplace.
3 Suggested Answers
SOURCE: Electric fireplace just blows out cold air
It would seem to me that the Thermal fuse has "Blown" this is an internal protection device that operate from heat... they often fail spontaneously, when this happens oftem all else works but no heat.
You will have to take it to a reputable repair shop/man and get a firm "Quote" for repair.
Posted on Jan 20, 2010
SOURCE: Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Posted on Feb 13, 2010
Need twinstar circuit board model 28e05-r pt #pro-082a
Bad news company...5 year old $500.00 device and the control board failed. NO parts...offered to sell me a new insert..No way Jose
Jan 17, 2014 | Leisure HOMEPRIDE Electric Fireplace...
I HAVE A RV WITH AN ELECTRIC FIREPLACE, ITS A HEF26 FROM CFM CORP, DOES ANYONE KNOW WHERE THE RESET BUTTON IS? IT JUST STOPPED WORKING, NO BLOWN BREAKERS
Hi I HAD THE SAME PROBLEM. I TOOK THE electronic BOARD OUT AND FOUND that the main power relay (that's the big black square on the board with the black and red wire connected to the top of it.) solder joints were loose. I bought a cheap soldering gun and resoldered the relay connections at the bottom of the board............Works Fine now................FC
Jan 12, 2013 | Heating & Cooling
Muskoka electric fireplace ,the switch doesnt work
  • Unplug the fireplace
  • Open up the fireplace to gain access to the inside.
  • Inspect switch for charring, melting, etc.
  • Inspect circuit board for charring etc.
  • If indeed the switch is the culprit: then...
  • Unhook the wires from the switch.
  • Remove the switch.
  • Bring the switch into your local hardware store or radio shack.
  • Buy a compatible switch - pay attention to amperage markings etc. so your new switch can handle the power.
  • Install new switch and re-hook up the wiring.
  • Close up the fireplace and enjoy...
Nov 25, 2012 | Heating & Cooling
My dimplex electric fireplace model HEF22 wouldn't turn on
take out fireplace flame, 4 screws, in the middle is a thin sq. black box 1.5 inchs sq. with an insulated screw driver pull it forward. you should here beep,
if u do- unplug-get a good tape,put tape to keep it forward, what happens is it pulled backwards and the two pins slipped out of the circuit board. dust while u arre in there. hope that works for u. mine is working.keep fingers ccrossed. HAPPY HOLIDAYS
Apr 10, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Flame has stopped flickering on our Century Heating electric fireplace, model HEF26. Fuses or motor?
Probably, neither. If there's no brightness at all, the bulbs are burned out and need to be replaced. If the brightness is there, but no flickering, then it's probably the motor or the shaft that the bulbs are on is stuck and can't rotate. Really not an uncommon problem with electric fireplaces, no matter who the manufacturer is. If you don't hear a humming noise when the flame function is turned ON. the motor may have overheated and shut down.
To test this, turn the Master ON/OFF Switch to OFF and unplug the fireplace from the wall outlet. Wait 12 - 15 minutes. Plug the unit back in and Turn the Master ON/OFF Switch to ON. Turn just the flame function ON. If it starts right up, the motor has cooled and the unit reset itself. If this continues to occur on a regular basis, contact the manufacturer's Technical Service Dept. If nothing happened after it was turned back ON, contact the manufacturer for replacement parts.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
I received a new circuit board for a Paramount DBL-2000-MS electric fireplace, but not sure where to start looking for it.
Its on the back panel of the fireplace...take all screws off back panel and its mounted on the other side...be sure to put you wires back in the PCB as they are on the old on!!!
Sep 06, 2010 | Vacuums
Electric fireplace just blows out cold air it is a Century model # is HEF26
Jan 20, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Charmglow electric fireplace flame does not flicker. Bulbs ok. HEF33WDG
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Oct 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pyromaster electric fire place motor for flickering flame
Any Vermont Castings stove dealer can order the parts for you.
Apr 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
