Question about Senco Air Tools & Compressors
I have a senco 35 and it is shooting the nail down through the air gap hole?
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 1388 Answers
SOURCE: porter cable roofing gun
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or enjoy
Posted on Dec 07, 2008
  • 1388 Answers
SOURCE: Senco SFN1 wont work
I have worked on many sfn1 with the problem that you describe. Here are a few things to check. Driver/piston too tight or too loose in cylinder or bent. It should be relatively easy to move the driver piston up/down the cylinder. Usually it should hold it's own weight and not drop down the cylinder. There is a washer that should be at the bottom of the gun under the bumper (washer part# bf0070). This washer must not be worn to the point that too much air will leak past or missing. Finally there is an oring that controlls return of piston (part # lb0077). Pull out the cylinder and find it located on the outer part of the cylinder close to bottom. Clean the port holes under the oring and make sure that the oring fits snuggly. Do not use oil in this gun. Oil will swell the rubber parts. I use silicone lube available form Lowes in the plumbing department. The grease is used to lube faucet orings. Good luck with your repair and email if you have questions.
Posted on Mar 16, 2009
SOURCE: How to unload nails from Senco FinishPro 35
when you pull the spring back like your going to load it .put your finger in the hole and push it .you'll see that the nails will be release.
Posted on Jun 21, 2009
  • 2176 Answers
SOURCE: Senco SN4 nailer not feeding
ther isn't a spring, it works on air to pull the driver back up. Have you tried oiling the tool as recommended (about 6 drops a day) If not then you have a problem with either o rings that are dried out or worn so they cannot keep the suction required for the tool to operate properly. Might also be a bent driver (doubtful). Go to and type in your model number and they list rebuild kits for this tool. If you need more assistance let me know and if I have helped with your request would you please rate this accordingly.
Posted on Sep 12, 2009
I can't shoot nails on my senco finish pro 35
Make sure you have the right nails and enough air pressure
Nov 18, 2017 | Senco Tools & Hardware - Others
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
Feb 16, 2017 | Senco Air Tools & Compressors
I have a senco sfn30 and it only shoots every second nail in. I had a look and the firing pin only retracts bout half way down???
that is the problem, I would take a look at the piston o ring for wear. Remove all the nails and air. BUMP the tool and see if the driver falls down and if so that would indicate a worn o ring. When replacing use a light film of oil to lubricate.
Jan 28, 2012 | Senco Air Tools & Compressors
Senco Framepro 602 has air coming from the top of the gun when the trigger is pulled and will not shoot the nails.
Sounds like the bar that slides down to push the nail is jamed you should disconect it from the air and check to make sure a nail is not stuck you should be able to look at the gun and see how to disasemble it in the front end to release it once that is done try some white grease on the part befor you reasemble it
Nov 20, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Framepro 602 only shoots air out a hole in the top when the trigger is pulled, occasionally shoots a nail but more often just shoots air
You have some worn out o-rings in your gun. Get a Senco repair kit #YK0360, use everything in the kit and your gun will be as good as new. Type "senco yk0360" in your search engine and shop around, the kit should be around $45 - $50.
Oct 11, 2010 | Senco Air Tools & Compressors
How to load nails into the magazine
Hi. Here are pix that show u what to do.
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Jul 12, 2010 | Senco FinishPro 35 FinishPro 15 SLS15 3...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Mar 28, 2009 | Senco Finishpro 15 Finish Nailer & Sls15...
Air Tools & Compressors Logo
116 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
