How do you open BATTERY panel of robertshaw 9400 thermostat? Front releases, but batteries are covered with 2nd plastic panel--flat, tightly fitted, with no give to sliding thumb pressure. Thanks!
Robertshaw manuals don't indicate batteries have a cover--only instructions are for outer cover of thermostat.
  • Heating & Co... Master
  • 17,455 Answers
Sometimes batteries are shrink wrapped together with a plastic sleeve. They are often special batteries that have soldered tags. If that is the case, they will lift out.
Posted on Dec 06, 2016
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
Thermostat says replace batteries... how>where.
Usually removing the front panel reveals the batteries.
Jan 15, 2015 | Heating & Cooling
Do you have instructions on how to change the battrery in a 2001 VW passat GLS?
Battery lives under windshield forward plastic panel and can be removed by peeling off the fire wall compartment seal to release the cover.
Put car in P or neutral.. remove ignition key. Obtain your radio code from records you have or dealership.
Open hood.
With 10mm wrench disconnect GROUND negative clamp on battery.
Ditto to Positive clamp. ( Do it in this order !.)
With 10mm socket, undo battery holder clamp in front of battery and lift away clamp and nuts.
Lift away battery.
Install new battery fitting the Positive battery clamp first then other parts as removed.
Do not bounce the GROUND battery clamp on the battery post as you install it as this can cause electrical damage to on-board electronics.
Jan 13, 2011 | 2001 Volkswagen Passat
How do i open the front cover on my DELL DIMENSION 4600?
Just check the below manual for more information on the same:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Feb 17, 2010 | Dell Dimension 4600 PC Desktop
How do I replace the battery and where is it located?
Procedure:
Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
The battery terminals are removed with the 10mm wrench
The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
Gently lift the battery out while holding the cables out of the way.
Tools required:
10mm wrench, small flat screwdriver
Procedure:
Tools required:
Procedure:
Tools required:
Procedure:
Apr 17, 2009 | 2004 Nissan 350Z
Heating & Cooling Logo
511 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
