Question about Crafts & Hobbies
Need replacement track for Mickey and friends around the tree train set where can I get it
  • 45 Answers
Try EBAY.
Posted on Dec 06, 2016
4 Suggested Answers
residentoccu
  • 161 Answers
SOURCE: 6-30068
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
Posted on Feb 13, 2013
SOURCE: i just set up or thomas lionel train. and the
If you can pull the roof off of Thomas there is an on/off switch within the cab. I don't know if you tried that at all..just a thought..
Posted on Apr 23, 2013
  • 373 Answers
SOURCE: There is a piece missing of the track and the first train doesn,t work ...can u help me ...I would to have it under the tree working ...ty.
The track must be complete/continuous to enable the power to reach the engine.
Posted on Nov 26, 2014
Dash at the zip line bridge instructions
Dash Zip-Line Bridge:This picture shows the layout of the track. Each section of track has a number on the bottom. Just put the sections together according to the map.2_1_2012_2_10_46_am.jpg
Jan 19, 2012 | Thomas and Friends Battery Operated Train...
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
The train set didn't come with directions and we can't get it to work. We have put batteries in it and now we are stuck! Can you help?
There is an on off switch on the side,also you have a selection switch on the same
side. Select either round track or straight track. Place the train on selected track,the
straight track with the arrows pointing in the direction of travel,then press the
Mickey symbol on the train body. Wipe the bottom of the train now and again to
make good contact.
Hope this helps and the little one has as much fun as my grandson.
Jun 27, 2011 | Fisher Price Mickey Mouse's Magic Choo...
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood...
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
May 23, 2017 | Lionel Toys
Mickey and Friends Arount the tree train set does no work
Hmmm, some of the Disney train sets had on/off switches It may have involved pushing the smoke stack like a button or adjusting a bell on the train. I would have thought that would have been in the instructions if applicable. But to answer your question, as the set is expensive and collectible, I'd have one that worked. And take very good care of the box. If looking for oil for the smoke stack, 3 in 1 oil or 3 to 5 drops of Marvel oil should work.
Jan 02, 2018 | Roman Disney Mickey & Friends "Around The...
Crafts & Hobbies Logo
405 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
