(copied from 'yep it broke' in another question) A means oil and filter change 1 means tire rotation and 2 means replace engine air filter and cabin air filter 6 means replace VTM4 rear-differential fluid
The P0670 means "Glow Plug Module Control Circuit" The P0195 means "Engine Oil Temperature Sensor" The P0184 means "Fuel Temperature Sensor A Circuit Internittent The P0383 means "Reserved by SAE J2012 The P0579 means "Cruise Control Multi-Function Input "A" Circuit Range/Performance Hope that can help you! ____________________ AK500 key programmer
Try making sure that you have your carburettor or fuel injection correctly set. Then check your engine timing. Also check that none of the major engine components are faulty. Dont rule out the possibility of a fuel leak somewhere in the system; so be sure to check everything thoroughly.
If this still does not solve the matter, get in touch with me and I will investigate the matter for you more in depth. In the meantime I hope this is the fixya for you, and I do look forward to hearing how you get on.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
what is the transmission? is it a 4L60-e or 4L80-e or 4L65-e the 4 means 4speed The L means longated the 60 means 6000 .lbs GVW and the 80 means 8000 .lbs GVW 5 mean there is a 5 gear planetary in the transmission and e =Electronic controlled total fluid is 11 quarts of Dex-tron.
CODE 12 MEANS BATTERY DISCONNECT.WHAT IT MEAN THE PCM WAS DISCONNECTED WITHIN LAST 50 KEY ON CYCLE. CODE 43 MEANS -CYLINDER MISFIRE.OR IGNITION COIL PRIMARY CIRCUIT.
