Question about Locks & Locksmithing
My lock just stopped working. It beeps fine when the numbers are pushed, but doesn't do anything. When I put batteries in it gives a long beep and then done.
  • 19,068 Answers
Google
make model manual
When you change batteries, you have to do things using the master key.
Posted on Dec 06, 2016
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
My pwerbolt is about 3 years old and has stopped working. I changed batteries and it worked about three times and does not respond when pressing the "lock" button or unlock when locking...
Aug 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
How long should I expect my lock to last? It is app. 3 years old will only lock & unlock app. 3 or 4 times then dies when the batteries are replaced... The batteries still have a full charge.when...
Aug 15, 2011 | Weiser Lock Powerbolt 1000 Lock
Some button on the keypad beep while others don't. After disconnecting the powerband and reconnecting, it beeps once when batteries were reinserted. After trying to set new codes, some buttons still...
Powerbolt is Beeping?
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Jul 24, 2011 | Weiser Lock Powerbolt 1000 Lock
Hi. Have had the lock on for at least 5 yars and has worked fine but now suddenly a problem. Locksmiths say its electrical so not their problem and vice versa so very frustrating.. Heres the...
Jun 25, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
I have an ABIT-an8 32x motherboard which was working fine, i didnt do anything that would cause any problems, but the next day it wouldnt work. whenever i turn it on it beeps 3 times, i cannot find what...
is a video card problem:
try replace the video card, for test at least.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 26, 2011 | Abit AN8 32X Motherboard
My lock works for awhile then stops. The beeps sound all the time, then stops locking & unlocking using the keypad. Then a day or two it works again.
Here's a link to the Powerbolt 1000 frequently Asked Questions page:
You will find this answer on that page:
Feb 10, 2011 | Weiser Lock Powerbolt 1000 Lock
Has started to beep whenever items plugged into
If it's more than 3 years old, you probably need new batteries.
If the beep started after plugging anything additional into the UPS, you may be in an overload state, and the beep is telling you that it's choosing to beep and not function as intended rather than smoking itself. Try unplugging a piece or two from it and see if the beep goes away. If not, probably just you're batteries giving out due to old age, they'll only give you 3-5 years.
Oct 11, 2009 | Dynex Computers & Internet
Locks & Locksmithing Logo
272 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
