SOURCE: We have borrowed a Qep 7
Try
http://qep.com/files/file/60007manual.pdf
Hope this helps.
///d///
SOURCE: have a QEP 24" bridge
blade might be to tight, loosen the nut that holds the blade,if that dont work,blades gotta be hitting something,if its a new blade measure it up to your old one to check size,make sure its a wet cutting blade,some continuous rim blades are made for hard material like granite,or dry cutting , good luck
SOURCE: need manual for 7-inch wet
Hello. Found the manual for you at:
http://www.northlandconstruction.com/products/4125/techsheet/QEP%2060087%207in.%20Wet%20Tile%20Saw%20Brochure.pdf
If this helped, please rate a four thumbs on this answer.
Thank You.
Go to your local dealer.
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
