Question about Health & Beauty
My merits vision sport chair won't work. It has one red light one yellow light and one green light flashing as well as the on off button flashing.
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
SOURCE: ps3 will not turn on
Your playstation is oficially broken and needs to either be replaced or repaired. Sony will fix this problem for $150.00 through their website(under warranty its free). This problem happened because it overheated and the soder melted to the point where the componets shut down and the unit went into safe mode :( :(
Posted on Jul 19, 2009
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Posted on Sep 07, 2009
HoverTech
  • 232 Answers
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
Peter Fix
  • 187 Answers
SOURCE: When I hit the power
Hello there satnamanu
If you have the brief flashing yellow light, then its followed by a red blinking light then you have the yellow light of death AKA the YLOD.
The lights are a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the YLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click here to know more on PS3 Fix Manuals which has helped so many people like you.
Good luck
Best regards
Peter
Posted on Sep 16, 2011
What does it mean when wrench symbol lights up on merits vision sport joystick controller
hi , it means there is a issue with the brake or motor ,,, make sue the connections are good ...
Let me know please
Regards
Rob
www.gewizrepairs.co.uk
Dec 26, 2014 | Merits P-326A Vision Sport
What does it mean when wrench symbol lights up on merits vision sport joystic controller
hi, sadly the controller test has discovered a problem , this can be related to the motor or brakes ... so check connections here
Regards
Rob
How do I speed up a Merit Vision Sport?
As the user of the chair, you will not have the ability to speed up your chair unless you have the specific programmer to raise the speed. Typically mobility specialist will turn your speeds down until you get used to the chair and then come back out when you are capable of driving chair at faster speeds. You will have to call the dealer who slowed it down or, another DME company in your area to have the chair speed adjusted.
Apr 30, 2014 | Merits Health Vision Sport Power Chair -...
My vision sport power chair won't move. the
says here thats a right motor fault, check the right motor connections and cableing
Sep 02, 2013 | Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Hand control flashes right to left on my merits power chair
Your joystick is in lock mode. Call Merit to find out how to unlock it or a power wheelchair dealer.
Nov 23, 2012 | Electric Health & Beauty
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
On off switch lights the red yellow green readings at full strength but continues to just blink when turned on.. get no response trying to use the joy stick. - the seat riser and speed buttons show no...
YY count the number of flashes ie 4 flashes pause 4 flashes pause. This will give you the error code and will tell what is wrong with your chair Check out my tip on Flash codes if you can't find them in your manual. Without fixing the problem that generated the flashing you won't be able to use the chair until the problem is fixed. If you want you could contact the provider that sold you the chair and have them troubleshoot the problem for you Hope this helps
Mar 07, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
112 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
