Printer turns itself off - Office Equipment & Supplies
I must press the on/off button several times before turning the printer on or off. How can i fix it?
If your printer had a paper jam and will not go online it is most likely a hardware failure. You will need to contact the manufacturer or a qualified technician to repair the printer. Make sure you have powered it off for several minutes at least, uninstalled and reinstalled the driver, and cleared the print queue. But if the printer itself is offline, none of those things will help as it is the printer itself that had failed.
Epson Printer Support
Mar 19, 2014 | Epson Stylus CX6400 All-In-One InkJet...
ML-2580N
Creg, did you try troubleshooting? From Printers and devices, check that your printer is a default printer and from printer properties, troubleshoot. It might fix itself or need driver update.
Mar 07, 2014 | Samsung Office Equipment & Supplies
The status indicator for paper continues to blink. The paper tray has been filled, The printer has been turned off to allow the printer to reset itself to no avail. The printer is a brother 5040.
try doing this
  1. Turn the printer off.
  2. Press and then hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself
Jul 11, 2011 | Brother Office Equipment & Supplies
I have mechine brother 5250 dn printer in that all lights r glowing culd u please provide the solutions
When all the lights are flashing together, turn the printer power OFF, wait 5 seconds and then turn the printer power ON again.
If the error continues, disconnect the interface cable from the back of the printer and use the following steps to reset the printer:
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
If this does not clear the problem, consult your dealer or your authorized service representative.
Jan 28, 2011 | Brother HL-5240 Laser Printer
Put a new drum in my hl-5140 two weeks ago, now the drum light is flashing again and nothing will print.
This should reset the DRUM counter.
Apr 14, 2010 | Brother HL 5140 Laser Printer
HP Phototsmart C8180 Ink system failure
The printer should have its own ON/OFF switch (or button).
Always use that control to turn-off the printer.
The printer reacts to the 'OFF' signal by properly shutting itself down, and then cutting the power to itself.
Sep 14, 2009 | HP Photosmart C8180 InkJet Printer
Printer turns off by itself
You need a new printer, its not worth getting it fixed, is it still under warranty?
SEO
Jul 24, 2008 | HP PSC 2410 All-In-One InkJet Printer
DRUM
Jan 14, 2008 | Brother HL 5140 Laser Printer
Printer Problem
power supply is probably faulty on the printer
Jul 11, 2007 | HP DesignJet 10ps InkJet Printer
jasbo
jasbo
