SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
SOURCE: print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
