Question about Health & Beauty
How do I know if I need a new battery? I thought my charger was bad so I ordered a new one. When it is plugged in the battery just shows red; not charging.
  • 81 Answers
Any of the major auto parts chains have free diagnostics on battery and charging systems. They can hook up a simple little box and tell you what's going on with your battery, and what's going on with your generator/alternator.
Posted on Dec 06, 2016
  • Anonymous Dec 06, 2016
    A generator/alternator on a wheelchair?
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
Computer will not turn on
You need to charge a battery at least overnight 8 hours for a real flat battery. During this time it must NOT be used at all. When you get it that flat, it will take some time to "Come Back" from flat. I suspect you just need to be more patient and leave on charger, when using it for at least a couple of days while working on it. After the 8 hour initial charge.
Mar 08, 2010 | Dell Latitude D510 Notebook
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
Chair not holding charge
It's your batteries. If they charge at all, your charger is okay, if not at all, new charger is in order.
Don't run your batteries down past half-disharge if you can avoid it. Charge daily or even more often if you are a road warrior, but try to keep them topped off. They don't have a memory.
Jan 22, 2010 | Golden Technologies Compass Electric...
Battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Mar 26, 2009 | Casio Exilim EX-Z77 Digital Camera
The battery to my fujifilm z10 camera wont charge when i stick it in the charger
I had the same problem. I had to buy a new charger...You could borrow someone else's battery and test yours..then you would know whether your problem is the battery or the charger. Also, just a thought The outlet you are plugging the charger into-is it a GFI plugin with a little red button on it? if so is the little red button pushed in?
Aug 06, 2008 | Cameras
Battery not charging
The charger may be bad. The red light shows that power is applied to it. So usally, unless the light itself is bad, no red light, no power.
Dec 27, 2007 | Vacuums
Health & Beauty Logo
94 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
