Question about Cell Phones
How to reset lg-4? - Cell Phones
Lg g4 reset
To perform a master reset:
1. Back up all data on the internal memory
2. Turn off the device
3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen
4. Quickly release and the resold the power button while continuing to hold the volume down button.
5. Factory data reset appears
6. Use volume down to highlight yes
7. Press power to confirm
8. Volume down again to highlight yes to erase all user data and restore default settings
9. Press power button to reset device
May 14, 2016 | LG G4
How do i hard reset my lg uk 410 tablet
Settings --> Resent menu 9.
Reset settings menu--> Master Reset options YES --> enter your 4 digit security code. The default code was 0000 unless you changed it. This will delete the phone entries. Security menu allows changing security code. You did backup anything you wanted to save, right? Note that customer service may remotely repair some phone problems.
http://www.hard-reset.com/lg-410g-hard-reset.html
Jul 08, 2015 | LG Tablets & eReaders
I need master reset for lg 265
Allows you to reset your phone to the factory default settings.
1. Press OK, 9, 4.
2. Enter the four-digit lock code and press OK.
3. Press 5 Reset Default and press OK.
4. Read the displayed message and press OK to continue.
5. A message will pop up that says "Preference settings will
be set to factory defaults.
Press <OK> to continue."
Press OK.
6. Use UP/DOWN keys to highlight an option (below) and press OK. Revert/ Cancel.
You can use LG Mobile Support tool to repair some LG cell phone model, after download select menu Customer Support > Recovery Phone
If you know LG 265 hard reset with buttons / keys pls leave comment.
Mar 28, 2014 | Cell Phones
How do I reset LG P500
Factory Reset on Menu Setting
1. From the main home screen, tap menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if required, then confirm by selecting Erase everything
Hope this helps,
If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again
2. Hold the Home and Volume Down button
3. Press and hold the Power button until the phone turns on
4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Sep 19, 2011 | LG P500 Cell Phone
I dont know the reset password of my lg cookie phone
When you have some problems with your lg secret, Do you know how to hard reset or factory reset the lg secret?
You can go to LG Secret's "Settings", then "reset settings", the reset code of the LG Secret was just 0000 (4 x zero). This reset the LG Secret phone, although i backed everything up i didnt lose any files but all the menus, themes etc were set back to default.
for more go to lg site http://www.lg-phones.org/category/lg-secret-info
Feb 28, 2011 | Cell Phones
How to factory reset a lg chocolate?
    The LG Chocolate mobile phone by Life's Good (LG) is used through Verizon cellular phone service. The Chocolate, also known by the model number VX8500, comes in a variety of colors and includes features such as a camera and a music player. The phone can be reset to factory default settings.
    Instruction
    1. Access the menu by pressing the "OK" button.
    2. Lightly tap the backwards button--the one with two small triangles pointing to the left--on your keypad.
    3. Press "OK," and then the number "5" button twice.
    4. Type in your lock code, a 4-digit pin.
    5. Choose "Reset Default" by pressing "3."
    6. Read the message on the screen and press "OK."
    7. Choose "Revert" by pressing the number "1."
Dec 07, 2010 | LG CHOCOLATE VX8500 Cellular Phone
I got my gt540 a week ago and i was playing around with the features.. on the pattern unlock the button that said forgot pattern.. i clicked it to see what would happen and now i am permanently locked...
LG GT540 hard reset LG Optimus full reset
WARNING: All of your data will be lost!
bingo .work done .
Dec 03, 2010 | LG GT540 Cell Phone
How do you reset the security code if you have
If you forgot or do not know the reset code for your LG Vu here is the way to do it. Works, just did it to mine.
To do a factory reset with your LG Vu cell phone, you must enter the Test Menu, the instructions are below.LG Phone Problem and solution
    1. Dial 277634#*# on the keypad to access the Test Menu
    2. Select Factory Reset
    3. Select Yes
    4. After the factory reset is complete, you must restart your phone for it to take full effect.
Jul 25, 2010 | LG Vu CU920 Cellular Phone
I forgot my password on my LG Chocolate how do i reset it?
call*228 and push 1 wen they start talkin and it will reset it and the code will be ur last 4 didgits of ur number
Apr 25, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Master Reset LG Lotus
1. Press Main Menu .
2. Select Settings .
3. In Settings select Reset settings .
4. Select Restore default settings .
5. Enter Security code as 0000 and press Ok .
Feb 27, 2009 | LG Secret ? KF750 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
