Looking for instructions on how to put a tv stand back together. lost instructions
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
bernardlunda
  • 318 Answers
SOURCE: Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Posted on Mar 26, 2009
SOURCE: toddler bed
Here is a website that has the instruction manual in PDF format.
http://common.csnstores.com/common/marketing/baby/delta%20childrens%20products/Toddler%20Bed%20Instruction%20Manual%20(dora).pdf
Posted on May 24, 2009
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
Posted on Jun 19, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
How can I put this together? I lost the instructions!!
you have a picture,lay the pieces out and you'll be able to pretty much tell what goes where by looking at the picture,You've put together a puzzle by looking at the lid of the box ? no diffrent.And don't forget to put a spot of glue on the stand and the screw, it will be much more sturdier.
Feb 19, 2015 | Miscellaneous
Tv stand
Have another read of the instructions. Have you put longer screws in to holes that required only shorter ones, and now the ones you have left don't fit?
Sep 07, 2014 | LG 32LB5800 32" LED TV 1920x1080, 60 Hz,...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
PT-60LCX64 no sound
check to make sure speakers in the menu are not switched to OFF. and inside set look to see speakers are plugged into a board somewhere.
May 31, 2012 | Panasonic PT-60LCX64 Television
I have lost the instructions on how to install the stand..
Go to the tv manufacturer's website and look under SUPPORT or DOWNLOADS.
Enter your tv's model number and download a copy of the USERS MANUAL.
You will find the model number printed on the back of the tv.
The instructions for removing / replacing the stand will be on the first few pages.
Good luck, post back if this helps or if you have trouble.
Jan 28, 2011 | Televison & Video
Technosonic lcd2017d stand lost
Hi I have a technosonic LCD3251 tv and am trying to take the stand off, as it is wall mounted now, i have taken all the screws out but i still cant get it off!! D you remember how you took yours off?
Jul 26, 2010 | Televison & Video
Putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Mar 09, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
