Question about Panasonic PT-52LCX15
Its a panasonic 52 inch model# pt 52lcx15 when turn it on the on green light flashes 10 times then shuts off a nd the off red light starts flashing wont turn on
Hey Beestergirl, I just had my tv fixed for 385.00
Posted on May 02, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @
hope this helps.
Posted on Feb 19, 2009
  • 1239 Answers
SOURCE: red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
Posted on May 03, 2009
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
  • 5138 Answers
SOURCE: PT-61LCZ7 is recently slow to turn on. flashes red for a long ti
Replace your Lamp visit Encompass Parts Distr online look up your model number or Call 1-800-638-3328 If Lamp has already been replaced then it will be either a defective Fan or Ballast board which is what turns Lamp on Make sure all Fans are running.
Posted on Nov 30, 2009
PT-52LCX15 when you turn on the tv the lamp comes on for about 2 seconds and it turns off then the power light blinks 5 times then the yellow
If you google how many times the light flashes with the t.v model that should tell you what your problem is.
Might be your bulb.
Jul 30, 2014 | Panasonic Televison & Video
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
My panasonic pt-56wx53g projection tv from 2003, shut off and the red light flashes 3 times every 10 seconds.
The 3 flashes is the error code for failed convergence. The Panasonic PT53WX53 Convergence repair kit fits your model. Its available at the kit contains the ICs, Resistors and the CD with step by step repair instructions.
May 29, 2011 | Panasonic PT-56WX53 53" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
PT-56LC27 52
If the light flashes red 2x's its a problem with the lamp. That's all I know. It's happened twice to me.
Dec 18, 2009 | Panasonic Televison & Video
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
Panasonic multimedia projection HDGT tv color spots displayed
Oct 18, 2009 | Panasonic Televison & Video
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-52LCX15 Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
