Question about Polaroid Televison & Video
Polaroid 50 inch TV reset button screen is staying black but its talking
SOURCE: 42' polaroid tv wont show screen still
it is a manufacturing defect. Mine had it. My advice is to never buy polaroid tvs. but anyway, here is a link on how to fix the problem...
Posted on Dec 29, 2008
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Posted on Aug 22, 2009
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
Posted on Oct 16, 2009
  • 192 Answers
SOURCE: I turn the TV and nothing. A black screen. The
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
Posted on Feb 09, 2010
  • 5 Answers
SOURCE: I have a polaroid 32
There are 2 capacitors located on a circuit board that have gone bad. They are located inside the TV. It is very easy to take apart and inexpensive to fix. If you know how to soldier you can do it or sent it away like I did to fix mine. On the back of the TV there are 3 screws holding on the cover. One is big in the middle and the other 2 are small on the ends. Remove them and slide the cover off. Remove the screws holding the metal cover and take it off.
The top circuit board has the blown capacitors. Located on the left top 2 small round tubes located at E17 & E18. Unplug the 3 or 4 connections carefully on the board and remove the 6 screw holding it in place. Take out the board and replace with new capacitors. I sent mine to JD Electronics in Poland Me. and he fixed it. I put it back in and it is fine now. I ordered the capacitors from Part # 493-2069-ND. They were $1.09 a piece.
Hope this helps...........
Posted on Oct 25, 2010
Polaroid TV screen will not always come on.
Are you talking monitor rather than tv? I have an LG 22 inch monitor and the on off button is on the bottom, If I don't hit it right or just tap it, it won't turn off but flashes. Where do you have it plugged in? Is it with some other electronics, or right to the wall outlet? I'm really at a loss as to what your problem really is. Are you using the remote? One quick fix might be the battery's in the remote. If they don't have enough power, short or no signal will be sent to tv or not being able to decipher it.
Feb 05, 2015 | Polaroid 4011-TLXB LCD TV
Tv has sound but no picture
I had similar problem with my Polaroid 42 inch. The screen would be fine for 10 minutes or so then go black. I found a work around that solved my problem and maybe you can to. What I did was remove the back panel of the TV. Make sure it is unplugged first. You should be able to see the electical board. Somewhere on the board may be a switch that says "Burn" or something with "Burn" in it. I set the switch to the "Burn" setting and the TV has worked fine ever since. Good Luck.
Sep 29, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
Tv blacked out no sound either, but power light comes on and off
just talked to polaroid because mine did the same thing......... power light is on and when you first power it on..... the polaroid screen appears for a second and then goes out............. they told me it sound like the control box and would cost me 225.00 to have it fixed............. does anyone know how to get a control box from some one other than polaroid....
my tv is TDA-03211C 32 inch with built in DVD
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Jun 12, 2009 | Polaroid FLM-2632 Television
I have a Polariod FLM 3232 hdtv 32 inch tv The
Most universal remotes don't have the screen mode button. So, your better off with the orginal remote for the TV.
The cheapest place I can find one for you is
It's going for $49.95
It's a little pricey, but it will have all the option buttons for the TV.
I hope I answered your question. Please rate me. :)
Mar 05, 2009 | Polaroid FLM-3232 Television
Polaroid flm373b
Try several different inputs.
Sep 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
