Question about Kitchen Ranges
I recently got a dunhill rollagas, the spark is too weak to ignite the gas (it will light with spark from a bic so I know there's gas, flint tube is clear, tried 2 new dunhill flints) any suggestions?
5 Suggested Answers
  • 1462 Answers
SOURCE: The flint on my gas
ease all the knobs up a little and see if that cures it
Posted on Sep 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: our gas stove repeatedly tries to lite
One of the small switches mounted on the gas valve stems has its little contacts fried together. Sometimes pots poil over and water gets into a switch and after 4 or 3 day that switch goes all propah again. To repair the prob you must find the bad switch and replace it. Remove a wire from one at a time till yo find the bad one. Or simply replace the entire harness making sure each swicth is properly locked into place. Simple ain't it? LOL
Posted on Feb 22, 2009
MNTECH
  • 1543 Answers
SOURCE: got gas stove flints wet and wont stop sparking?
The problem is actually caused by water getting into one of the burner ingition switches. This will generally correct itself by just drying out over time. (usually within a day) Just leave the range unplugged for a while.
Posted on Oct 09, 2009
Testimonial: "that did the trick and no repair man was needed thanks"
  • 2006 Answers
SOURCE: burners won't light automatically. Will light
If none of the igniters are working then it is probably the igniter module which is relatively easy to replace on most makes and models.
Posted on Jul 27, 2011
How to change the flint on micro torch roburn mt-770
There is no flint.
It uses a piezoelectric igniter. Not really replaceable.
Point it at yourself at arms length and see if you can see a spark when you press the button to start it.
Here is a video which shows how to adjust the air-gas mixture when the torch is new.
Jul 21, 2016 | Miscellaneous
The spark ignition on the right front have gas but does not ignite at all. All three the others have sparks.
flint or electric probe to earth needs a clean or
closer inspection to replace the ignighter
Jul 02, 2016 | Kitchen Ranges
Burners won't light automatically. Will light with a match. Flint doesn't spark anymore. Can flints be replaced and by whom?
Jul 27, 2011 | Whirlpool Kitchen Ranges
Blazer pocket micro torch will not spark. Gas comes out, but no spark to ignite it.
try to open up the part where the spark would come from. there should be a screw on the bottom or top to open it. This is where the flint would be.
The flint is probably worn down or it broke (you can buy new flints at pretty much any convince store around they are i believe $1-2 for 5 of them.
replace the flint and you will have a spark.
May 03, 2011 | Omega Blazer Self - Igniting Butane Micro...
MY KENT GAS HEATER WILL LIGHT WITH A MATCH SO GAS IS GETTING THROUGH BUT FLINT IS NOT WORKING TO IGNITE THE FLAME/GAS
Your igniter may well be a Piezo Electric device... a spring loaded hammer strikes a crystal and the crystal generates a high voltage which causes a spark. They sometimes break down mechanically and the hammer no longer hits the crystal. You can sometimes repair them (rarely) and sometimes buy a replacement unit.
May 09, 2010 | Heating & Cooling
My grill will not ignite. I tried both ways. What could be wrong?I hear the gas but it wont start
Hello. It could be a bad igniter. Go to any hardware and get a lighter, like this BIC
http://www.grillwithbic.com/
If it lights this way, clean the igniter, if it still doesn't spark, replace the igniter. Joe
Mar 20, 2010 | Weber Genesis Silver A Grill
How to fit a flint in a vintage dunhill pistolttable lighter?
On the underside opposite the flint there should a screw head.
Remove this screw (take care, there will be a spring inside!) .
Turn it over and the remains of the old flint should drop out.
Insert new flint and re-assemble.
Jan 16, 2010 | Watches
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
