My Harman advanced feed has stopped. The feed motor is only a couple of months old. What else might it be?
2 Suggested Answers
  • 46 Answers
SOURCE: Harman advance when turn on auger motor runs non-stop until you shut power off. What should I check?
Do you have the dial turned to 'test'?
Whats the status light say? Is it solid on or blinking a code?
Posted on Oct 25, 2017
Testimonial: "No it is not on test!!! solid light"
I cleaned my Harman Pellet stove today and when I went to start it the feed motor won't start. The blower runs for about 15 sec then shuts down
Test the feed motor with a jumper and wire power to it directly, if that fails to make it run you have a defective motor.
Dec 27, 2016 | Pool & Spa
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ... > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Forums Home > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Can the infiniter 100 red laser pointer pop balloons?
1.) Plug in foot pedal
2.) Press reverse button and hold while turning on the power switch.
Advance through test segments by pressing up/down key
• Raise irhe needle bar to highest position and push
• Lower the needle bar to lowest position and push
• Tum the handwheel and check the feed dog position
• Not working correctly
• Stepping motor (zigzag) get default position
• Feeding, tension motors get default position
• Feed dog goes to home position
• Replace stepping motor
• Replace tension sensor
Jul 02, 2014 | Office Equipment & Supplies
Will not turn on . started filled with water then shut off and will not power up now. it still has water in machine this washer is a little over one year old .
Sounds like the timer motor didnt engage. Soon as the fill switch activates, when its full, the timer motor advances forward and starts the cycle. Since the water stops when full. Then part of the switch is working. The one that is nc at same time the one that is no engages. Try advancing the dial couple clicks into the cyckle then pull back out.
May 31, 2010 | Washing Machines
Well it it might not. What exact model TV?
Your high-fidelity equipment should get TV-related audio from the same place the TV gets it - Cable, DVD, BD or Sat. A digital feed each of them will carry TRUE Dolby Digital audio. There is little sense in diluting TV-related audio through a TV and it's marginal audio electronics that are usually limited to analog stereo.
May 20, 2010 | Harman Kardon AVR 225 Receiver
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
Rear window wiper works for a few days or weeks
Check the plug is completely plugged into the motor. Maybe a bad connection in the motor itself. Also check the switch, try wiggling it when turning on.
Mar 06, 2010 | 2003 Oldsmobile Silhouette
Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Jan 02, 2010 | Kitchen Appliances - Others
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
26 people viewed this question
