The E3 light keeps flashing and I don't know what it means??
2 Suggested Answers
  • 4338 Answers
SOURCE: e3 flashing wat does it mean
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button
3 times for Orange EEPROM reset.
Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
3 times Orange EEPROM reset
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
Dometic fridge is flashing E3 on LED Panel what does the code mean
bad control board check by removing thermistor from board run over nite if ok replace thermistor if not bad control board
Jun 21, 2015 | Dometic Refrigerators
No what should i do know, don't have tool scanner
Try turning ignition switch thre times, without start engine ( ON / Off / ON / Off / ON ) and count the blinks light two short means a 2, space and one short flash measn 1, so code 21.
Keep us updated.
Oct 15, 2011 | 1994 Plymouth Voyager
Brada ypm-06c air conditioner not cooling the room down no matter what i do! keep getting E3 code. is it normal for the lcd lights to keep blinking and blinking! SO annoying when in the bedroom at...
You need to clean the filters and coils on this unit so the error code will go away and the unit will work like it should. If it can't get clean air across the coils it will freeze up and not circulate any air. Most common issues are dirty filters and dirty coils that prevent air flow. Is the fan working to blow air? this code could also mean the fan is not working. Check on these and let me know.
Aug 05, 2011 | Heating & Cooling
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
Jan 29, 2009 | Omron Body Fat Analyzer from
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 | Dishwashers
Dishwasher Hoover HD98E
E3 means water is "not heating" for this model. Check the heating element, thermostat/thermistor or printed circuit board with power OFF.
Sep 11, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
