Question about Toys
Can you show me a picture of where I need to place the pegs and how to
  • kakima Dec 06, 2016
    Hi Donna Mann, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Place which pegs into what?
I bought Master mind for kids game, made by pressman. It did not come w/ any instructions. I need rules for the game to play the game.
The two players decide in advance how many games they will play, which must be an even number. One player becomes the codemaker, the other the codebreaker. The codemaker chooses a pattern of four code pegs. Duplicates are allowed, so the player could even choose four code pegs of the same color. The chosen pattern is placed in the four holes covered by the shield, visible to the codemaker but not to the codebreaker.
The codebreaker tries to guess the pattern, in both order and color, within twelve (or ten, or eight) turns. Each guess is made by placing a row of code pegs on the decoding board. Once placed, the codemaker provides feedback by placing from zero to four key pegs in the small holes of the row with the guess. A colored (often black) key peg is placed for each code peg from the guess which is correct in both color and position. A white peg indicates the existence of a correct color peg placed in the wrong position.
If there are duplicate colours in the guess, they cannot all be awarded a key peg unless they correspond to the same number of duplicate colours in the hidden code. For example, if the hidden code is white-white-black-black and the player guesses white-white-white-black, the codemaker will award two colored pegs for the two correct whites, nothing for the third white as there is not a third white in the code, and a colored peg for the black. No indication is given of the fact that the code also includes a second black.
Once feedback is provided, another guess is made; guesses and feedback continue to alternate until either the codebreaker guesses correctly, or twelve (or ten, or eight) incorrect guesses are made.
The codemaker gets one point for each guess a codebreaker makes. An extra point is earned by the codemaker if the codebreaker doesn't guess the pattern exactly in the last guess. (An alternative is to score based on the number of colored key pegs placed.) The winner is the one who has the least points after the agreed-upon number of games are played.
Jul 19, 2011 | Video Game Consoles & Games
How to put the pegs on?
You need to have a BMX bike with a threaded axle. A bike with quick releases will not work.
The first thing you're going to want to do is go ahead and loosen the bolts on that side of the rim, take the bolts completely off, along with your spacers, pull them off and then you'll slide the peg onto the axle. And you're going to have to have an extension to get into the peg. The easiest way to get the peg on is to take it, put your bolt, your washer and then slide your peg into place on this, or you can put it on there and then you just slide it on, and then tighten your bolt back down, and that will hold your peg into place
Mar 15, 2011 | Conspiracy Shadow Little Ones Pegs Bmx...
The literature, manual instructions did not come with the product. There are only pictures. Is there a place where I can go to download the instructions for the Polaris Outlaw 12-Volt Childs atv?
If you go to Peg Perego than you can download the pdf. file.www.pegperego.com go to 12Volt and you can look up Polaris Outlaw. I already checked it out for you and it is waiting for you to download. The pdf. file on acrobat is FIUS51001G148.pdf .This is the owners manual for this model of ride on atv.
Dec 27, 2010 | Polaris Outlaw Ride-On
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
How do i install saddlebags on a 2007 honda shadow vlx vt600?
I've got a 2007 Shadow and recently put on a set of saddlebags. What you do is use a large allen wrench or star wrench on the seat strap to take out those two bolts, and then you slide the seat towards the back of the bike (or perhaps you need to slide it to the front, I forget, its just the "picture-hanging" connection, <=0 is the shape of the hole on the seat, and on the bike beneath it is a peg, with the seat hole large enough to slide the peg through, but once you shift the seat to its natural position the head of the peg is at a place too narrow to come off, hence the sliding motion to remove it) . Then it is smooth sailing, just lay your saddlebags over the peg with the seat removed, and try and put the seat back without disrupting the bags too much, which can be hard since its a pretty snug fit. Hopefully that helped, I don't know if the request was talking about post market support frames or something
Aug 04, 2009 | 2005 Honda VT 600 C Shadow
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Unable to place 5 point safety belt on peg perego aria
Contact Peg Perego & they will give you answers over the phone or send you a manual for free (email or snail mail).
800-671-1701
May 01, 2008 | Peg Perego Baby Gear
Psp and umd
Open the UMD door. You will see a large peg sticking up and behind it a small one. Press down on the small one, it is either Black or Gray. This is the senor switch that senses a UMD Disc is inserted. When you press this little peg down, look at the Laser to see if it lights up. If it does not light up. You need a New UMD drive. If it does light up. Press the peg down again, but this time look at the Spindle to see if it spins any at all. This is hard to see. If it does not spin in the slightest. You need a new UMD drive. If you do not have problem with lighting or spining, then get you a Q-tip and some Glass Cleaner./ Clean the lens on the laser.
Nov 29, 2007 | Sony PlayStation Portable (PSP) Console
Toys Logo
131 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
