Question about Bosch Dishwashers
Bosch silence plus 46 dishwasher will not drain
SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Posted on Jan 15, 2008
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
SOURCE: my bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Posted on Nov 14, 2009
  • 457 Answers
SOURCE: Bosch dishwasher will not drain
Posted on Feb 25, 2010
SOURCE: what is E25 on my
e25 means water is running back into your pump. Bosch man just fixed mine and told me that what the code means. Make sure your drain hose is high enough.
Posted on Mar 14, 2012
Bosch silence plus showing fault E24. Have lost our manual . How do we fix this ?
Check the manual online:
Jul 01, 2017 | Bosch Dishwashers
My dishwasher, a Bosch Silence Plus 48dba, makes one beep about every 20 minutes.
Interesting...You have a whole LOT of COMPANY... (upset users)
Evidently this machine has been tormenting its OWNERS since early 2005.
My Search got "banishing the beep bosch" (actually pretty funny)
Found great answers to your question BEFORE I was able to PULL UP any technical SPECIFICATIONS.
Most notably in 2008 by RACHELL G ("best answer") at
Where-in you will find several approaches for TRANQUILITY... Most notable...
It tells you two buttons MUST be SIMULTANEOUSLY PRESSED to put the WASHER into PROGRAM MODE.
What display to look for... "0" from display.
More importantly... Tells US the changes must be SAVED to take effect on EXIT (below)
Rachel G is on the right track. Do you see a line under your wash selection buttons? Find the button at the right end of the line (probably labelled Pots & Pans, Half Load, or some other wash setting). Hold that and the power button down until you see a 0,1,2 or 3. Hit the button again till you see a 0 in the display.
Then hit the Power button to lock in the selection.
12/10/2015 ADDENDUM:
Went online and pulled down YOUR manual...
These instructions are a wee bit more precise:
Cycle completion signal:
The cycle completion signal alerts you when a cycle completes and the dishwasher has waashed and
dried the dishes. You can choose to disable the tone or adjust the volume.
To activate:
1 With the unit OFF, press and hold the RIGHTof the two Cancel/Reset buttons and then press and hold
the On/Off button.
2 When the light on the Cancel/Reset button you are pressing illuminates and the tone goes off,
release both buttons.
3 Press the RIGHT of the two Cancel/Reset buttons again until you achieve the desired volume or until
there is no tone (to turn cycle completion signal OFF).
4 Press the On/Off button to save the setting.
Hope these are more helpful.
Dec 09, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba dishwasher not draining it says E24
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Mar 02, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at:,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more:
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
User Manual for Bosch silence plus dishwasher
Hi my dishwasher is showing an E01 error could when I switch it on . please advice
Nov 02, 2012 | Dishwashers
How to cancel cycle on dishwasher
On my dishwasher you have to press and hold the Stop or Cancel button for 5 to 10 seconds.
Sep 28, 2012 | Bosch Dishwashers
My Bosch Dishwasher model shx46a05uc/46 will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
Sep 20, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
Bosch SHX68M05UC/46
It sounds like you've had many eyes on this already, but it sounds like the drain hose isn't looped behind the unit. You want it looped (or arched to 19" or taller from the floor) behind the unit to prevent siphoning of dirty water from the sink drain or disposal. An Air Gap will also solve the siphoning problem but is prone to clogging, as I found out the very hard way. I have written a guide to help. It is here.
Jul 21, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
71 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
