Question about Coffee Makers & Espresso Machines
Brand new black +decker 12 cup coffee maker CM0960BF. Brewed three pots of coffee an two pots of tea. Now it won't brew
  • 24 Answers
SOURCE: Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
Posted on Dec 10, 2007
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
My black+decker CM0960BF 12 cup coffee pot won't brew
Time for a new one. They are not repairable and the average life is 5 years or so. Ours is the same model.
Dec 06, 2016 | Coffee Makers & Espresso Machines
What can I do if my 12 cup black and decker coffee maker wont brew. Power is on
These devices are unfortunately made cheaply these days. If it is fairly new, say within 6 months, contact the manufacturers customer support line (found on documents or their website) and they often just ship you a replacement.
Otherwise, if the water is not coming out and spilling over, make sure that the release in the brew basket is opening when the pot is placed under it. Some of them stick and then the coffee overflows.
Oct 01, 2016 | Applica Black And Decker 12 Cup...
Coffee pot not working
old and tired needs replaced . this is how they die
Sep 05, 2016 | Black & Decker Black&Decker Coffee Maker -...
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
Black & Decker 12 cup programmable seems to have ghosts
There is an issue in your main control board which requires a capable tinker to change out using a good one cannibalized from another identical coffee maker. Virtually all models of B&D coffee makers are sold for parts on eBay, but finding the capable tinkerer is the harder part.
Apr 15, 2014 | Black & Decker Coffee Makers & Espresso...
Instructions in manual for programming brew time is incorrect
Here's the Black & Decker products page where you can find another manual.
Here is a list of all their supported coffee makers.
If linking directly to a search result dosn't work use this link and enter, Coffee Maker, in the search box.
Dec 16, 2013 | Black & Decker CM1050B
Brand new, first run, leaking?
You must have the carafe lid ON. The reason is the lid has a dome on top that pushes up to let the brewed coffee come down. With the pot off look in there with a'll see that the 1 inch dome pushes up on the spring loaded stem.
You MUST have the lid in place or the brewed coffee won't drain into the pot.
Aug 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
