Question about Refrigerators
80971is leaking from push lever. How do I stop it
  • Refrigerators Master
  • 9,771 Answers
The plastic tubing has cracked from the heat of the light in the door. Repair kits can be had from appliance parts stores or online.
Posted on Dec 06, 2016
    Top Expert:
  • 36,477 Answers
Replace the valve. This is a common failure item.
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
I have an old UHO 83 digger. The problem is that when I walk the digger it moves about a metro and stops, when i release the lever and push it forward it will move again and then stop again until the lever...
i used to know some one that had a hitachi. was always having problems with it not moving. if i remember right it was the brake leaking think its air system and it was just leak. he had it fixed and added an air line indicator fitted think the boom works on the same system. if i remember right there is a foot brake and a lock brake lock brakes hydraulic . and the normal braking. but in the event of the air brake falling the hydraulic brakes take over. but this is from memory and it was a long time ago you dont see meany round here any mor they all jcb's and other makes.
Mar 24, 2014 | Cars & Trucks
My 84 300 turbo d won't shut off when I turn off the key. I have to open hood & hit engine stop lever.
You have a vacuum leak. If you open the hood and look on top of the engine, there is a lever one the right side (looking at the front of the car) with a red "Stop" decal on it. Push the lever and the engine will stop. Look for any small plastic vacuum tubing that may have come disconnected. If you dont find any, it may be a line inside the car. For temporary relief, you can pull the rubber junction from the vacuum tube that goes through the firewall to the inside of the car and cap it. If the engine now shuts off with the key, that does mean your leak is inside the car (4 door locks and trunk release are all vacuum operated and have tubes going to them).
Dec 11, 2013 | 1984 Mercedes-Benz Mercedes Benz 300 Class
How do I remove the drawers on a kobalt HP2331-KB toolbox
Pull drawer all the way out to stops.
Locate the right and left levers on the slides.
Push left lever down abd pull lever out as far as it will come.
Push right lever up and pull lever out as far as it will come. (Use needlenose)
Now pull drawer out.
Too bad the written instructions have us pull the drawer out rather than the levers first.
Jun 08, 2013 | Measuring Tools & Sensors
The red pressure relief button on my GE Smartwater whole house water filter system is leaking what do i do to stop this
I had the same problem. The valve is not seating properly. I first took a plastic bag and placed it over the unit so it didn't spray all over, then, pushed the button several times to try to flush it. I then shut the water supply off (or move lever to bypass) and removed the cannister that holds the filter. I activated the red button several times until it looked like it seated well. Keep as much water in the cannister(sump) as you can and still have the filter seated properly. Screw it back on, and open the water supply slowly to fill the rest of the way. Don't push the red button again, but instead open a faucet in your house for around 5 minutes to let air circulate out. If the red button still leaks, you may have to try a few times. If it leaks just a little it may stop after a day or so. Once you get the red button to stop leaking, don't push it again! Just always use the open faucet method to work the air out. There will still be some air bubbles for awhile, but will work out within a day
Sep 13, 2012 | General Electric GE SmartWater Household...
How do I enable samsung tl105's digital zoom?
From the manual:
Optical zoom TELE : Push the Zoom W/T lever to the right to
enlarge the subject.
Digital zoom TELE : Push the Zoom W/T lever to the right again
in optical 4x zoom mode to enable digital
zoom (software tele). Release the Zoom
W/T lever to stop digital zoom (tele). When
the 5X digital zoom reaches its maximum
magnifi cation, it will not enlarge the image
further, even if you push the Zoom W/T
lever.
Jul 18, 2010 | Samsung TL 105 Digital Camera
The water dispenser will sometimes drip and doesn't stop. It doesn't stop by pulling forward on the lever, I have to push it in as though I'm dispensing more water and that usually stops it. If I don't...
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Apr 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Dishwasher repair
The most common reason why your machine has stopped filling is not the valve, but more likey you have had a leak and the base of the machine is full of water.
If you take the lid off followed by the left side panel ( held on with 2 torx 20 screws ) the lid has two clips at the back and pushes back from the front.
at the bottom of the metering tank towards the front you will see a Red lever going up to a mircoswitch and down to a float. push the lever down to see if the microswitch reacts. if so the base is full of water. empty out and test. try this first, if no luck get back to me.
Mar 23, 2008 | Dishwashers
Water dispenses without pushing lever
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Jan 28, 2008 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
