Question about Vacuums
Our vaccum is around 5 months old and it does not work properly. We've already unclogged it. How do we get a new one with the warrently?
    Top Expert:
  • Vacuums Master
  • 50,501 Answers
Take it to an authorized service agent for a warranty check
if it is unrepairable you will be entitled to a warranty replacement unit
if it has be repaired by any other than an authorized agent , the warranty will be void
Posted on Dec 06, 2016
Motor just makes 4 or 5 small clicking noises when you pull the trigger, then stops. The little lights illumintae around the "max" button as well. However, the motor does not engage in the slightest. ...
fiter is dead clogged up inside. you could wash it 50 times still wont unclog. simple fix, just buy a new filter and empty bin more often in the future and wash filter every month and fit new one every two years
Jul 15, 2017 | Dyson DC35 Handheld Vacuum
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Sep 20, 2012 | Bissell 1716 SpotLifter PowerBrush
I have a dyson animal dc24. It is 7 months old and has stopped working. The hand tool is working fine but when I insert it to engage in normal vaccuming the suction stops. I can hear a strange air sound....
I'm sorry to hear your DC24 Animal isn't picking up as well as usual. Although I note you've already checked for blockages, it sounds as though this is likely to be the cause of the issue.
To locate and remove any blockages, please follow the steps shown in our online Support guide:
http://support.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use, the filters should be washed at least once a month, as shown in the video below. Use cold water without detergent, and allow the filters to dry somewhere warm for at least 24 hours before replacing them in the machine.
I'm confident this will resolve the issue, but if you'd like any further assistance or advice, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Mar 04, 2012 | Vacuums
I purchased Shredder Model BD-S600 on 5/6/11. This was to replace another Black & Decker Shredder that I had for only a few months also. Today, when i attempted to turn shredder on to shred some...
If it's like my BD-S600 your motor is already burned out!! Same thing happened to me with this shredder after 3 months of minimal home use. I had to call them and pay $13 to send shredder back to them to have a new one sent to me, and I have already been on the phone with customer service due to problems with the new one after 5 minutes of use! Good luck to you; I know I will NEVER purchase a Black and Decker shredder again! My last shredder (a Brother) lasted 8 years with no problems and I really miss it!!
Jul 05, 2011 | Black & Decker Vacuums
Vacuum won't ****. Bag is new, belts are fine.
Some vacums have a filter for the exhuast usually covered with a small slotted clip on cover look for one or more of these and remove and clean then be sure area where filter is held is free from debri then replace. Pull the bag out and look for the hole where air is pulled in from the bag compartment check to see that area is clean and free from debi. Finaly disconect hose from both ends then use a straightened coat hanger, curtain rod, or even a broom handle to pass through the hose to be sure there is no blockage reconect and try again, be sure to have bag attached properly. If none of this helps chances are the blockage is within the motor of the Vacum.
Thumbs Up if this Helped you!!
Jun 21, 2011 | Hoover Vacuums
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I unclog a bissell vaccum? I'm not just talking about unclogging the hose, I need to unclog the complete vacuum cleaner. HELP!!!
Well firstly, whats the model number and do you have the user manual to hand?
If the main hose has been unblocked, then it could be the main dirt channel which is blocked just after the moving roller brush panel. A long pipe cleaner or wire brush can remove this blockage easily rather than taking everything apart.
Apr 18, 2008 | Vacuums
Electrolux lux vaccum cleaner hose and fitting/nozzle needed
Call your local Aerus/ Electrolux branch. If no luck with that try www.aeruspa.com
Hope this helps
Jan 09, 2008 | Vacuums
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
