Question about Refrigerators
How to clean the metal fan in the back - Refrigerators
  • Refrigerators Master
  • 10,137 Answers
It is only necessary to keep the dust off the blades and the fins that the fan blows on. It is not necessary to make then shiny brite. Simply vacuum the blades and the fins.
Posted on Dec 06, 2016
My siemens frdge is making rattling grrrrr!!! Noise evey now and then.recently it makes noise around 3am then it stops.what should i do?
hi, Lets do some simple things that you can do EZ.
1. Unplug keep doors closed.
2. Pull out fridge be careful of the water supply line for ice maker.
3. Remove the cardboard or metal back panel.
you will be able to access the fan and you will need to vac all the dirt and clean the fan blades with degreaser
Shoot WD 40 on fan shaft and rear of fan motor.
Vac and clean the cooling line grid on the back of fridge.
4. If it is still nosey defrost it unplug 12 hrs clean drip pan under fridge and M/T. Plug in and let it get cool. This will de-ice the crossovers.
Mike
Mar 12, 2018 | Cars & Trucks
The condenser fan freezes up, I can push start it but it still stops periodically. Is there some maintenance I can do? I have cleaned it up but wondering if there is something I can lubricate
using a spray with tube lightly spray the shaft as it goes into motor and on back if able to spray where shaft ends against back housing ---I've had fans last for long time and others just to late to save it keep in mind if lubing dont work will need to replace it and since you have accessed it changing it is not hard
Jul 12, 2016 | Refrigerators
I have a small hawaiian breeze fan that is all metal with a small metal stand and I took it apart to clean it and I removed the fan blade as well upon cleaning. I put it back together and now it runs way...
did you take any wires off or did you take the switch out ?
If you only removed the fan guard and blade then I have no idea what could have happened
If you removed the motor or wires then possibly you have wired it wrong .You could od a search on the mfg website ands ee if they have a wiring diagram
Sep 22, 2013 | Dryers
Fan very loud all the time
probably easiest if you take the back cover off your laptop, and remove the fan completely. then remove your fan. clean all the dust from this, and also clean any air vents. obove the fan should be a metal grid thing. clean all the dust from this! this is the heatsink. usually you should use a can of compressed air. but i use a vaccum cleaner - USE VACUM CLEANER AT YOUR OWN RISK. IT CAN CAUSE STATIC ELECTRICITY DAMAGE.
Oct 14, 2009 | ASUS M51Sn-C1 Notebook
Fan blade noise
This is most of the time due to excessive dust covered on processor heat sink try cleaning in side with pressure air by removing keyboard.
Mar 13, 2009 | Acer Aspire 5050 Notebook
Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Jan 12, 2009 | Oreck XL Professional Air Purifier
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Taking apart the fan
Whew!! Finally figured this one out!
How to Clean Seville Classics Tower Fan
Approx Time: 1.5 hrs
Tools:
Long Phillips head screw driver
Metal Skewer or very thin/sturdy screw driver
Empty egg carton (to keep track to the hundreds of screws)
Leatherman or small pliers
Toothbrush
Vacuum
Make sure the fan is unplugged!
1.Filp fan over and remove the 2 larger screws that hold the pedestal together (keep screws organized)
2.Remove the 4 inner screws that connect to the base
3.Remove base
4.Unscrew the 6 screws that hold the lower rear cover
5.Remove lower rear cover
6.Unscrew the 4 screws around the underside of the fan case (in a half circle)
---Very Important in cleaning---
7.Replace pedestal! Yes all 6 screws (4) smaller inner screws and (2) larger screws
8.Stand fan upright (lower rear base cover removed)
9.At top of control panel (buttons) locate a small circular hole (top of fan) towards the rear handle
10.Take the skewer or thin/sturdy screw driver and stick it in the whole
11.Gently but firmly pop up the control panel. (it took some patience, working around the panel but it popped up.
12.Remove (4) screws and remove the secondary plate
13.Remove (3) larger screws toward the front of the fan and (4) smaller screws around the edge
---Leave the screws in the metal plate in place---
14.Remove the 3rd cover
---Now the fun part!!---
15.To remove the metal screen push the plastic front in slightly at the edge with the open plastic vents (this side doesn't have tabs). There is a bent edge that is held in place by the plastic screen on this side.
16.Continue to pry the screen backwards and push edge with tabs (side of plastic front with no vents) towards the front of the fan. There are 3 metal tabs that slide in the plastic front at that edge.
---The front plastic vent face should be left in place, all of the control wires run through it---
17.With metal screen off, you can use your vacuum (highly recommended) while you scrape the "turbine" with the toothbrush. There are a lot little turbine edges and they get quite dirty. Vacuum is a must!! In fact, I had mine running the entire time.
---The plastic turbine does not come off and must be cleaned in place---
18.Putting it back together!!! The metal screen tabs might have bent a little when you pried it off, I used a leatherman (pliers) to bend them straight. With patience you slide the tabs back into the plastic slots (working from the bottom up is best), slowly start to place the screen back around the fan. When you get to the side with the bent edge, you must push the plastic vent face inward (bottom up is easiest) in order to snap the screen around the edge.
19.Now, while not letting the plastic front slip from the metal screen, grab the plastic plate and slide it on top (make sure to get the metal rod back into the rubber gasket) and push down. This will hold the metal screen in place.
20.Put all the screws back in place and snap the control panel back on.
21.Remove the bottom pedestal in order to put the rear plate back on.
22.Replace the pedestal.
This is definately a fan made by engineers with disposable income that can afford to buy a new fan every year instead of cleaning it on a regular basis! I have had my fan for the past 4 years and always leave my windows open. After sometime, the performance when down, barely eeked out a breeze and shot dust bunnies on to my carpet. Often it would overheat and shut off automatically.
After all this time, I finally figured out how to clean it and boy, was I suprised how much dirt and junk this fan collects.
Hope this helps all the frustrated tower fan owners!!
Jun 22, 2008 | Seville Classics MSC10166 Tower Fan
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
