Question about Miller Welding Tools
I have a Miller Bobcat 225. Engine and AC side OK, no welding output. Looking for a check list to troubleshoot with. I am able to do check with multi-meter. Just don't know values that are normal
    Problem Solver:
  • 10 Answers
Most common problem for no output is the brushes, you should also have approx. 3 ohms resistance across the slip rings. Can get you more info, but will require the serial number of the welder.
Posted on Dec 06, 2016
I have a Miller Bobcat 225. It will not start and run with out pouring gas into the carb? I have changed fuel line and filter? Help!!! Please
Check fuel pump and check carburetor bowl for stuck needle. If fuel was left in engine stuck needle or plugged jets. Confirm that choke is fully closing when cold.
Hope this helps?
Fuel Pump.
Jun 26, 2017 | Miller Welding Tools
Miller Bobcat(Gas)machine AC output to aux. power receptacles, does not meet required voltage. Only 70% required voltage 120 and 240.
On a Bobcat, the big knob needs to be turned all the way up to 10. If it is, then the engine speed (RPM) might be too slow at fast speed.
Apr 01, 2017 | Miller Welding Tools
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Dec 12, 2014 | Bobcat Miller 225 Welder Generator 907209...
Miller bobcat 250
remove the side doors, and top cover, make sure your brushes are making correct contact against the slip rings, there is a flat mounting panel behind the range control switch, you will see 2 white fuses in their holders, check these fuses, one controls AC output the other controls weld current output.
May 19, 2014 | Welding Tools
Bobcat 225 runs good but wont weld.Welded great one week prior
Probably your machine overloaded. Check the fuses F1 and F2 and if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket. Check your owner's manual for an ilustration of it.
Aug 05, 2011 | Miller Welding Tools
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
367 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
