Question about Coffee Makers & Espresso Machines
My black+decker CM0960BF 12 cup coffee pot won't brew
  • 1 more comment
  • Michelle Sullivan Dec 06, 2016
    It's brand new. Just got it yesterday
  • Andrew Taylor
    Andrew Taylor Dec 06, 2016
    Oh :>)
    You plugged it in, you read the instructions, you put the coffee into the filter in the top and you put the water in. You pressed the 'Brew' button and nothing happened? Did you also press the timer button, that allows the machine to start up as you get out of bed?
  • Andrew Taylor
    This is the machine? Not like my model. It is less that 10 bucks. The quality has really gone downhill. Just take it back and get a refund. Must be made in China!
    https://www.walmart.com/ip/BLACK-DECKER-...
  • Coffee Maker... Master
  • 19,031 Answers
Time for a new one. They are not repairable and the average life is 5 years or so. Ours is the same model.
Posted on Dec 06, 2016
    It is New. Just got it yesterday
  • Andrew Taylor
    Timer?https://smedia.webcollage.net/rwvfp/wc/c...
    SETTING AUTO BREW TIME
    1. Press PROG button. The AUTO light flashes several times. Digital clock
    displays 12:00.
    2. Quickly press HOUR button then MIN button to select the time you would
    like automatic brewing to begin (for example, 7:15 A.M. Make sure the P.M.
    light is not on.)
    3. Press AUTO button again, holding it down until the AUTO light stops
    flashing. The digital display changes to time of day.
    4. To check preset auto time, press PROG button and preset auto time is
    displayed. Press AUTO button to reactivate the timer.
    5. To cancel Auto Brew function, press I/O button.
  • 24 Answers
SOURCE: Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
Posted on Dec 10, 2007
  • 19 Answers
SOURCE: Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
Posted on Jan 19, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
SOURCE: replacement carafe for Black & Decker ODC325N Spacemaker 12-Cup
You can have mine for the cost of shipping
Posted on Dec 04, 2009
What can I do if my 12 cup black and decker coffee maker wont brew. Power is on
These devices are unfortunately made cheaply these days. If it is fairly new, say within 6 months, contact the manufacturers customer support line (found on documents or their website) and they often just ship you a replacement.
Otherwise, if the water is not coming out and spilling over, make sure that the release in the brew basket is opening when the pot is placed under it. Some of them stick and then the coffee overflows.
Oct 01, 2016 | Applica Black And Decker 12 Cup...
Coffee pot not working
old and tired needs replaced . this is how they die
Sep 05, 2016 | Black & Decker Black&Decker Coffee Maker -...
My black and decker coffee pot wont brew everything seems to be fine all the lights and the clock work but when i push on it wont start brewing
There is a momentary contact switch that is probably. You gran get one at the mfr. or maybe locally. When you press the brew button, you should hearing it engage . That would be a sound and a click like something has connected. If there is no sound, then your momentary contact switch is bad. Not too expensive. Probably a 5-10 minute job.
Feb 02, 2013 | Applica Black And Decker 12 Cup...
I put the coffee on to brew and it stops after a few cups
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
May 30, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
My Black and Decker Spacemaker coffee Maker will not turn on. Pluged-in and will not turn on. Recently replaced the recalled coffee filter brew basket.
We had this same problem and it turned out that the inside if display and circuit board caught on fire and melted inside. File a report with the USCPSC and call Black and Decker. They are sending us a new model free of charge but they are also telling me to send them the coffee pot free of charge wtih postage paid. I refuse to do this for 30 days because the Consumer Product safety commission wants me to keep it for 30 days to investigate
Oct 29, 2009 | Black & Decker SpaceMaker ODC440B 12-Cup...
Coffee Makers & Espresso Machines Logo
66 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
