Question about Tappan Kitchen Ranges
Tappan electric range shut down how to reset it
aborcass
  • 2651 Answers
SOURCE: Tappan 30 Series Range ignition system
no fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
Posted on May 08, 2008
breddi2
  • 126 Answers
SOURCE: Tappan electric range, brand new - top heats up
Call the manufacturer and ask them what to do, they can advise you as to what to expect when unit operates and possible cause. Most ranges on broiler will have some heat transfer to top, but this sounds extreme
Posted on Apr 26, 2009
  • 71 Answers
SOURCE: tappan electric range pro design model TEF 362
yes you can replace it....you actually get the entire top not just the glass....Tappan is a spin off of Fridgidaire so you would have to get ahold of them to get the top just need to give them your model number....price usually ranges from $200 to $350
Posted on Oct 03, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
  • 21 Answers
SOURCE: put on the self cleaning...and some wires in the
Hello
Is the stove directly wired? The code says the wire coming from the breaker box should be connected to a four prong 50amp range receptacle. Then a 50amp four prong range cord from the receptacle to the range. There's a clip on the back of the stove that connects the neutral wire to the frame of the stove. It has to be removed and the green wire coming from the cord connected to a green screw on the stove to separate the neutral form the ground. Get a licensed electrician.
John
Posted on Jan 07, 2010
How to fix f13 error code on a tappan stove
Good Afternoon Friend,
I understand that you are receiving an F13 error code on your Tappan range. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I ask that you please leave your model number in the comments as well. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Frigidaire FEF336BC Electric Kitchen Range
My Tappan oven is built in and 23 years old. I put it on self clean. It did, but the noise won't shut off. I turned the oven to off, but the noise still goes on. There is no way I can unplug it.
go to your homes power panel and find the circuit breaker or fuse controlling this circuit and shut off the breaker or pull the fuse,this will power down the unit
Nov 07, 2010 | Tappan TGF320 Gas Kitchen Range
Put on the self cleaning...and some wires in the back sparked and it shut down the circuit breakers? ITs a electric tappan
Hello
John
Dec 12, 2009 | Tappan TEF242 Electric Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Apr 25, 2009 | Tappan TEF242 Electric Kitchen Range
Tappan gas oven dooor won't unlock
We were able to solve the problem by accident. As I think I mentioned the door must of locked when we were cleaning the control panel. Anyway the door locked and the burners would not ignite.The door was open so you were not able to shut it to try and clear it. I searched the owners manual, there were no solutions as to how to reset the Range. I even checked the manufacture's web site. I got down to inspect the door and ran my hand along the inside edge of the oven and there was a button on a spring. I pushed on it and there was a hum and the latch opened and the Range must have reset. It's working perfect now.
Dec 07, 2008 | Tappan TGF320 Gas Kitchen Range
May 08, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TEF242BW oven stopped working
Have you tried the broil setting yet?
This will tell you if the upper element comes on.
If so, you may have a burned bottom element.
Apr 05, 2008 | Tappan TEF242 Electric Kitchen Range
Tappan Gas Range
Most likely has "ON PILOTS" As opposed to (electronic ignition/ Ignitors).. Change the stove to a more efficient model and being gas do "NOT" Do it yourself Period!.(Please)..Install should be tested and approved..
Call a local professional specialized in LP/Natural Gas Appliances. Flex lines on older Stoves tended to break down causing leaks as well as older construction codes where Black pipe feeds and shut-off valves break down after time. Sorry for the Negative info but Ive seen some Slum-lord homes in my days doing service calls.. Keep it shut off until you can get it fixed professionally..
Aug 08, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
