Question about Samsung Washing Machines
How can I open my samsung front load washing machine to renBalance the load?7 kg j845
  • 868 Answers
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
Posted on May 20, 2008
SOURCE: I have j1045 front load
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Posted on Mar 15, 2009
  • 5 Answers
SOURCE: door jammed shut
normaly this is due to water still in the drum
Posted on Sep 21, 2009
SOURCE: Our samsung j845 front load washing machine won't
Posted on Sep 29, 2009
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting
Posted on Sep 30, 2009
Hi: My samsung washmachine J845 had problems. it wasnt pumping out the water.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
May 19, 2011 | Washing Machines
The door of our J845 wont open. its been 3 hours since the cycle finished
hawe you disconected from electriciti or no. pull door inside- if not helping - time switch is faulty.
Mar 18, 2011 | Samsung WF203ANW Front Load Washer
Cannot open the front door on an Electrolux ECO 7 kg front load washing machine. Feels as trhough the door clip has broken
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
Jan 10, 2010 | Electrolux EW1200i Front Load Washer /...
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
Door jammed shut
Sep 20, 2009 | Washing Machines
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Jun 02, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
