Question about Hampton Bay Dryers
Replacing 4 wire hampton bay capacitor. Original is 2 brown on one side and 1 purple 1 grey on other. New one is 1 brown on one side & 3 on other side: 1 yellow, i purple and one grey. Wire?
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
TBlessed 1
  • 61 Answers
SOURCE: ceiling fan wires
is the old fixture still installed?
Posted on Oct 17, 2008
SOURCE: 3 speed switch 4 wires where do they go????
corrected by trial and error
Posted on Feb 11, 2009
SOURCE: I need to wire a 2HP 110V ge motor to 220V
I think the only place you will get this info is from GE -- and good luck with that.
Posted on Apr 29, 2009
Hook up 5-wire fan capacitor
U hook it up the same way the old one was hooked up. Did you take notes or pictures of the prior cap connections?
And without a model number how do you expect anyone to really be of assistance? Huh?
Aug 29, 2016 | Hampton Bay Dryers
Replacing Hampton Bay 3-speed pull chain fan switch. I do not have the original wiring diagram. I have a new ZINGEAR pull switch and need to wire L, 1, 2 and 3 with available wires: black, white and b
L-Black 1-Gray 2- Brown 3- Purple
If this doesn't work you have the wrong switch. It might look the same on the outside but that doesn't mean it's the same on the inside. You might want to check your capacitor to make sure it's not going bad!
Oct 14, 2014 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
5 wire, 4 speed Zing Ear Switch ZE-268S5
Dec 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
I need a basic wiring diagram for a 3spd, 3 wire capacitor ceiling fan with reverse slide DPDT switch. The rotary pull chain switch was removed along with the cap, so i do not know how to put a new switch...
Try L-BLACK 1-GRAY 2-BROWN 3-PURPLE. IF THIS COMBO DOESN'T WORK. BLACK WIRE GOES TO L , 123 IS YOUR SPEEDS YOU WILL HAVE HOOK THEM UP BY PROCESS OF ELIMINATION FIGURE OUT WHICH IS HIGH MED & LOW. IT SHOULD BE 1-HIGH 2-MED 3-LOW.
Jul 24, 2010 | Hampton Bay Dryers
Wiriring a 4-way switch
Sorry to be so late in answering. Mine broke in October and I just got around to fixing it.
The Black goes to L
The Grey goes to 1
The Purple goes to 2
The Brown goes to 3
Oct 16, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
43 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
