Question about Ovens
Is there an adjustment to have pilot light stay on after given length if time. Our rev oven pilot takes longer then one minute. About 1 1/2 min
  • Ovens Master
  • 18,319 Answers
No it is a safety feature that the pilot has to heat up the thermocouple to assure the main gas valve that the pilot is alight and hot.
Posted on Dec 05, 2016
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
Can't keep the pilot light lit.
Your safety valve is bad. You could try repositioning the thermocouple probe but bootm line is these cannot be repaired they must be replaced. The new safety orifice ain't gonna be adjusted you will have to do that.
Match the height of the old one with the new part by turning the orifice with a nice fitting wrench post your model number so I can look up just what you have. Checking oven safety valve: HERE72a2330.gifa7f3db4.jpg
Apr 04, 2010 | Ovens
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
When i ignite the oven and let go of it the gas goes out all the time..
It's usually down to carbon clogging the pilot light. This typically happens where gas is on a meter like we have. Everytime the gas runs out, dust and other particles get sucked along into the nozzle where the pilot light is.
The best solution is to try cleaning it. I'd recommend trying to run the vacuum cleaner nozzle over it if you can (with it turned off of course) and perhaps even try cleaning it with a toothbrush (preferably an old one of course as nothing tastes worse than soot) and if this fails, let me know.
Nov 13, 2009 | Ovens
Pilot light wont stay on
yes there should be a screw to turn near gas control knob at front there is one for each burner and the oven
Aug 26, 2009 | Ovens
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
Nov 06, 2008 | Ovens
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
My oven
I have found that the pilot will get fouled with a light colored powder due to inpurities in the gas. I usually clean with a tooth brush and pipe cleaner (when cool - no pilot). Otherwise the thermocouple may need to be changed, or at lease re-adjusted to be nearer to the pilot flame. Cleaning every year is prudent.
Apr 21, 2008 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
