Question about Cameras
I have a card I have never been able to use - Cameras
  • kakima Dec 05, 2016
    Hi Linda DeBoer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What type and capacity card? What make and model camera?
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 | Cameras
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
What are the rules for sorry revenge
Setup:
Place the Big Red Pawn (BRP) in the center of the table. Everyone gets on home board and 4 pawns of the same color. Distribute the Quick Rules Cards and then shuffle the deck and deal 5 cards to each player. The remaining cards go in the center as the draw pile. Turn the top card of the draw pile face up next to the pile to start the discard.
Play:
Once everyone has their cards, turn the BRP on and when directed, tap it once to determine who starts the game. On your turn you will either play a card or tap the BRP.
Card play options:
Play 1 card on the discard pile, same color as the top card.
Play any number of cards on the discard pile that are in ascending numerical sequence These cards do not need to color match.
Play a wild card.
If you can play on the discard pile, you must play. You cannot voluntarily tap the BRP
Wild Cards:
Slide card- the slide card allows you to play any amount of numbered cards from your hand which match the color of the slide card. The slide card does not need to match the current face-up card. If you cannot play at least one matching numbered card, you may not play the slide card. The exception is if the slide card is the last card in your hand, in which case you may play it, and the person to the left must follow the slide card rules, if possible.
Safety zone card- May be played on any color, but ends your turn. The following player may play any color on top of it.
Sorry! card-May be played on any card. After playing the Sorry! card, select any other player to tap the BRP. After they have followed the BRP's order, turn passes to their left.
Special Cards:
Special card rules are printed on the cards.
1-When playing a sequence, you may choose to play a 1 on top of a 12.
2-If the 2 is the last card played by you, you may choose to take another turn.
4 and 10- If either the 4 or the 10 is your last card played, turn order reverses. In 2 player games, the 4 and 10 act as a "skip" card, skipping the opponent.
11-If the 11 is your last card played, you may choose to swap hands with any player.
Tapping the BRP:
If you cannot play at least one card, you must tap the BRP. If you are selected by a player playing the Sorry! card, you must tap the BRP. To tap the BRP, simply press down on the top, and listen for his orders, which you must follow. They may include drawing cards, giving cards away, taking cards from others, etc. If you must tap the BRP on your own turn, due to not being able to play a card, you may make any legal play with cards resulting from the BRP's order before the run passes to the next player.
Going home: To move a pawn home, you must empty your hand of cards. When you do so, place one pawn on your home board and draw a new hand of five cards. The winner is the first person to place all four of their pawns on their home board.
Read more: http://wiki.answers.com/Q/How_do_you_play_sorry_card_revenge#ixzz1NmMqv0HG
May 29, 2011 | Toys
I need the part number for an HP Media Card Reader to fit an HP DC5000M.
» HP 16-in-1 Media Card Reader with PCI Card - Overview - c00604206 s.gif Overview for HP 16-in-1 Media Card Reader with PCI Card
» Ricoh Media Card Reader Driver - HP Business Support Center s.gif Version 2.13.00.05 - This package contains the Ricoh Media Card Reader Driver for the supported notebook models and operating systems. The Ricoh Media Card Reader driver provides ...
» Ricoh Media Card Reader Driver - HP Business Support Center s.gif Version 2.14.00.05 - This package contains the Ricoh Media Card Reader Driver for the supported notebook models and operating systems. The Ricoh Media Card Reader driver enables the ...
» Ricoh Media Card Reader Driver - HP Business Support Center s.gif Version 2.13.00.05 - This package contains the Ricoh Media Card Reader Driver for the supported notebook models and operating systems. The Ricoh Media Card Reader driver enables the ... » HP 16-in-1 Media Card Reader with PCI Card - Overview - c00604206 s.gif Overview for HP 16-in-1 Media Card Reader with PCI Card
Apr 12, 2010 | HP DC5000M PC Desktop
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
Sound card, multimedia card, tv tuner card.
sound cards are card fitted in pc to get sound when soundc slot of motherboard is malfunctioning or driver is not available,multimedia cards are cards for storage connected through USB and display cards are used when video slot of pc is malfunctioning or there is no driver.higher memory display cards are known as graphic cards.
Sep 28, 2008 | Compaq Audio card Sound Card
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
