Where do i find fuse of dlp projector? - Office Equipment & Supplies
  • 6,694 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Dec 06, 2016
Replaced the lamp on Toshiba TDP T-45, now it won't turn on. Does it have a reset button or fuse?
Uninstall...reinstall.... Double check for touching wires then check fuse box for blown fuses
Jun 28, 2016 | Toshiba TDP-T45U DLP Projector
If you are getting no indicators on the projector then you need to replace the power supply or the fuse on the power supply
Dec 16, 2014 | BenQ W5000 1080p 1200 ANSI 10000:1 DLP...
In146 dead
First check wall outlet is bad or a house fuse has blown. Try another outlet. Test / replace if bad: power cord, fuse and on/off switch on projector. If these do not solve the problem, consult a professional service person.
May 27, 2014 | InFocus IN146 3D Ready DLP Projector
May i replace LCD Projector Dlp/Dmd chip with DLP projector Dlp/Dmd chip ?
LCD projector have only LCD panels in the Projector
DLP projector have only DMD chips in the projector
there is no DMD chips in the LCD projector
there is no LCD panels in the DLP projector
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,motherboard ,powersupply,ballast... with high quality and competitive price.
Hope to cooperate with you.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
Feb 21, 2014 | Office Equipment & Supplies
Message says airfow blocked, turns on for about a minute then shuts off
1. Remove the air intake filters on your DLP projector. As explained by InFocus, a manufacturer of LCD and DLP projectors, each DLP model will house the air filters in a different location. However, for most DLP projector products, the filters are accessible by unclipping a simple plastic latch.
2. Wipe the air filters with a small cloth dipped in rubbing alcohol.
3. Blow compressed air into the unit's vents. This will force some internal dust out of the DLP projector, but you may still need to open up the unit for additional dust removal.
4. Unsnap the main cover from your DLP projector. Because DLP projectors need periodic lamp replacement, the main cover is rarely secured with screws or bolts. However, if the DLP projector's cover does not snap off, then you'll want to inspect the unit for possible screws or an alternate release latch.
5. Reach in and remove visible dust globs with a paper towel. Be careful to avoid touching the lens, as fingerprint smudges can diminish DLP projector image quality. If you accidentally smudge the lens while picking out dust blobs, wipe the lens with a dry, lint-free microfiber cloth.
6. Spray compressed air into your DLP projector to remove any lingering dust particles.
7. Close up the projector and reattach the filters.
Sep 26, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Dell DLP projector won't turn on. Does anyone know a fix?
have you changed the lamp recently, or cleaned the air filter.
The internal fuse may be blown, or a whole lot of other things may be wrong, so we need more information otherwise it's off to a technicain to check it out.
Mar 17, 2011 | Dell 1100MP DLP Projector Multimedia...
No pwer to my D530 dlp projector
check the power cable first. also check is there is power on the wall out let to which the projector is connected. if all ok then the projectors smps power supply may be faulty. for testing the same u have to open the projector. fist check the input fuse. if fond faulty, do not insert a new one immediately. check is there is any component fault in the smps. only after insert the fuse.
Dec 29, 2010 | Vivitek D530 Projector
Is there a fuse in the projector?
Yes, typically near the power plug source. you will just need to look around
Jun 16, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
My lg dlp is blowing fuses as fast as i can replace them. what could cause this?
chances are there is a short on the power supply board. at this point you may need to replace it.
Dec 11, 2009 | LG DLP Projector 1400Lum RD-JT30...
Infocus dlp projector
Hi Gratztech1
If none of the light are coming on this could just be a fuse that has gone.
Open up the top cover of the unit and look on the Powersupply Board for a fuse and replace it ( it is the board with the AC socket on it )
Should do the trick !
Thanks for using Fixya and if you need any further assistance please send me a request.
May 13, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
79 people viewed this question
