How d9 i replace the screens on water inlet - Washing Machines
GE washing machine Toploader will not fill with water
see this causes and remedies: God bless you
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control. see the diagram attached
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Jul 18, 2012 | Washing Machines
I have a top load kenmore washer the spin cycle works but it wont fill up with water.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. Here is a video at that will walk you thru the testing a water inlet valve. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Oct 06, 2010 | Kenmore Washing Machines
Washer takes a long time to fill up on any cycle hot or cold whats its problem?
Oct 05, 2010 | Roper RAS8445KQ Top Load Washer
No cold water to machine.
Oct 05, 2010 | GE WBSR3140DW Top Load Washer
Hot water will not flow into machine and cold sometimes trickles and sometimes flow
Oct 02, 2010 | Kenmore Washing Machines
I have a Westinghouse washer model # WWS833ES0. It will not fill with cold water.. only hot. And it does not fill any water on any rinse cycle. Any ideas as to what parts I will need to fix this? Thank...
Sep 27, 2010 | Westinghouse Washing Machines
Hot water goes into the washing machine. Cold does not
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. If the buzz is coming from the solenoid replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
May 07, 2010 | Whirlpool LSR7333 Top Load Washer
My washer keeps filling with water in the off position at first the cold water would barley run and know it runs slow all the time in the off position it's a roper washer
Your water inlet valve has probally failed.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available.
Apr 07, 2010 | Roper RTW4300SQ Top Load Washer
Washer just hums when time for the water
Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 14, 2009 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
