How to get the inner tub out of the plastic outer tub
5 Suggested Answers
  • 29 Answers
SOURCE: Looking for replacement bearings for the outer tub
Get the bearings here.
http://www.thebigbearingstore.com/index.html
Part numbers
6206-2RS
6207-2RS
You'll also need the seal kit.
These guys have them
http://www.pcappliancerepair.com/index.html
Part number
12002022
I'm not affiliated with either company. If you can find them elsewhere cheaper more power to you.
Maytag told me I had to buy the tub for around $700.
I am halfway through this repair on mine. I haven't ordered the parts yet.
All the parts should cost you around $60-$70 + shipping.
The bearings are very difficult to remove. Some douche online rents a tool for $400 deposit + like $150 rental fee. I pounded mine out with a metal rod. The tool would probably be easier.
Good luck.
Slatrom
Posted on Sep 28, 2009
  • 93 Answers
SOURCE: whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Posted on Dec 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: an item fell between the inner tub and outer tub.
This video show how it is done:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 23, 2010
caroldon
  • 17130 Answers
SOURCE: there is a noise between the outer tub and the inner drum on seimens washing machine
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For tips to replace bearing click on: removing bearings
Posted on Jun 26, 2012
Inner tub base rubbing on outer tub
Sounds like you need to replace the bearings supporting the shaft. Not an easy job without the proper tools and if you haven't done it before.
Nov 07, 2015 | Fisher and Paykel Washing Machines
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
Water leaking from bearing at back of drum
you better get at this soon,the lip-seal is gone from the outer tub and now water has penetrated the bearings behind this lip-seal,the longer you wait the harder it will be to remove these bearings and if its a plastic outer tub you can destroy this tub when removing the old bearings,the inner tub needs to be removed,the rear access needs to be open the motor pulley removed,the c-clip that secures the outer bearing needs removing then the inner tub can come out the front to access these bearings for replacement
Mar 24, 2011 | Indesit W 123 Front Load Washer
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front seal not supporting drum, drum flops violently, doesn,t leak. seal wont stay on drum.
it sounds like you may have tub bearing issues or your suspension springs or shocks may be missing or broken. The front seal is just there for sealing, thats its sole purpose.
Basically there is two parts, the inner stainless steel drum and the outer plastic tub housing. Reach inside and see if you can move the inner stainless drum up and down any significant amount? If so the bearings are most likely shot. If its pretty solid but the outer plastic tub moves, its most likely a suspension issue. You can take off the top to get a much better view of the components.
Oct 24, 2010 | Frigidaire ATF6000ES Front Load Washer
I replaced the coupler between gear box and moter and the cogs in the agitator now when spinning out the washer makes grinding noise
Murph!
Good job on the coupler and agitator cam! Way to go!
Now for the grinding noise... I assume that it wasn't making that noise before you worked on it, right? (except for the noise it makes when the coupler has failed. It make a kind of grinding noise, too.) So I'll assume that this is a different grinding noise.
2 things will cause this in "spin".
1.) Something is caught between the inner and outer tubs. Since you've had the cabinet off, you know that there is a perforated steel inner drum (the one with holes in it) and a plastic outer drum to contain the water. I've seen nails, paper clips, etc... get through the holes of the inner tub and get caught there. When the unit goes into spin, the object will spin along with the inner tub and rub the outer tub making a scraping/grinding noise.
To find out if this is the problem, remove the agitator again... yes the entire top and bottom portions of it. Now CAREFULLY inspect the inner tub and look for anything that may be stuck in the holes. It'll be small, so use a good flashlight.
2.) The "drive block" has cracked/broken and allowed the inner tub to drop to the point that it's grinding on the outer tub base. This one is a bit more intense than the fix above. If you would, please verify that there's nothing in the inner tub before we proceed to the next step.
Note----> I don't doubt that you can't handle the next repair. It's just that I want to eliminate the simple stuff before moving to the more complex stuff.
Let me know what you find, OK? Also... BEFORE you remove the agitator, look at the distance between the bottom of the agitator and the base of the inner tub. Use your finger for measurement. You should NOT be able to fit the tip of your finger between the two. If you can, write back 'cause then we'll be going into the drive block (#2) repair.
SG
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
Feb 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
