Question about Cell Phones
Where is the SD card located? - Cell Phones
How do I change storage settings from internal to sd card
The ZTE Zinger sets default memory storage automatically. If an SD card is inserted, then the SD card is the default storage. If not, the internal storage is used.You cant change the default storage location.
SD card ZTE Zinger
May 29, 2015 | ZTE Cell Phones
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
How to download an avchd video from an SD Transcend card
1) Plug the SD Card in you PC's card reader,
2) Open an Windows Explorer (WIN-E) window and locate your SD Card,
3) Browse the SD card and find the video file you want to COPY (why did you say DOWNLOAD ?),
4) Copy (CTL-C) it, and paste (CTL-V) it on your local disk !
Aug 27, 2014 | SanDisk MobileMate SD Plus 5-in-1 Media...
SD card location for Compaq Presario CQ50
There isn't a sd card slot on the computer the best thing you can do is buy a usb sd card reader
Jul 26, 2014 | HP Compaq Presario CQ50-110US Laptop
Just got a motorola citrus and can't take picture without an sd card. Where does the sd card even go?
The SD slot will be located behind the battery compartment. Most of the time these phones are pre-installed with a micro SD card. If not, a 2G Micro SD card would be sufficient for most things. roughly 8-10 dollars.
Aug 26, 2011 | Motorola Mobility CITRUS Smartphone
My HP Photosmart M425 camera turned itself on somehow and decided to run a diagnostic. Now, I have no clue what buttons got accidentally pushed, only that when the diagnostic was finished all our pictures...
i think you should put your sd card in your computer and then try to locate the pictures on the sd card,
if you can't locate the pictures on the sd card then i am afraid you will have to retake the pictures
May 28, 2011 | HP Photosmart M425 Digital Camera
I forget my 2 gb sd memory card in nokia 6303i . how i unlock?
Pull out the SD card by opening the back cover of your phone, SD card slot is located near phone battery. You'll find a small lock switch on the left side of SD card, Make sure that it is slid UP in unlock position, You would not able to edit or modify if SD card is locked.
Thanks...!!
Nov 18, 2010 | Nokia 6303i Cell Phone
I'm unable to format my 4gb Sandisk High Capacity SD card. The response I'm getting is that the disk is write protected.
Hold the SD card so the label is upright and facing you. Locate the switch on the left side and slide it up to unlock it. If you have a Micro SD card, put it into an SD card adapter. Slide up the switch on the adapter to unlock it.
Insert the SD card into your computer. If you do not have a built-in SD slot on your computer, then connect it with a USB adapter.
Open the Computer icon on the desktop. A window will open with a list of the available drives. Locate the drive the represents the SD card. The name of the drive may differ depending on you named it, or what the default name is.
Right-click on the drive and select Format. If it asks what you would like to format it to, select "FAT32" and click Start.
Oct 23, 2010 | SanDisk 4GB microSD High Capacity Memory...
SD card can not be accessed on Sanyo NVM-4370
Did you hear a beep when SD card is inserted? Did you also try to hard reset the unit using the On/Off switch located at the bottom of the unit? Try with another SD card and see if the SD option is selectabe. If all have tried I suggest you to exchange for another unit. HTH.
Mar 02, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
