Question about Kitchen Appliances - Others
I do not have a manual. It comes on fine . the stirring works. Why is it not getting hot?
    Top Expert:
  • Kitchen Appl... Master
  • 77,932 Answers
The heating element is burned out is a likely cause.
Posted on Dec 05, 2016
Can a replacement stir rheostat be purchased for a fisher scientific hot/ stir plate model 11-500-4sh.
The value of the rheostat will part of the numbers on the metal case. You should be able to get ons from Radio shack or online.
Aug 11, 2016 | Kitchen Appliances - Others
Corning Pc-320 hotplate/stirrer. Where can I get a manual?
Why do you need a manual there is nothing to do. To make the stirring function work, you need a magnetic stir bar (just a Teflon coated magnet. There is a motor-powered spinning magnet under the ceramic plate.
The heater is not thermostatically controlled. It just heats more as you turn the dial more.
May 17, 2015 | Corning Pc-320 Laboratory Stirring Hot...
I did my chicken wings a while ago but the chicken coating were all gone because of the stir paddle, can I remove the stir paddle if I am cooking with bread coating?
Probably tyou don't coat correctly.. Dip your chicken wings in flour than in well stirred egg and finally coat it with brear. Hot oil should cover your chicken, Fry till it get's golden, move it carefully
Feb 10, 2015 | Tefal Actifry Family Ah900015 Low Fat...
Ice doesnt come out of ice maker , seems to get stuck. Have to stir ice around
Hello Phyllis Hopkins, thank you for your inquiry!
It sounds like you could have a possible issue within the dispenser, auger, or auger motor of your Frigidaire refrigerator. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
Sep 08, 2014 | Frigidaire Refrigerators
MWG9115SB suffix A - cooks very hot. Don't have a manual
I always recommend that folks put food off-center on the turntable to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
If the turntable or stirrer (if equipped) fails, that will cause hot spots and overheating.
Otherwise, you may have a failing magnetron.
In case it helps, the owner's manual is here:
If you need more help, contact Emerson here:
Oct 15, 2013 | Emerson Microwave Ovens
Car insedent
Low profile tyres lol! It's only flat at the bottom.
Jun 03, 2013 | Toys
What is a hot plate stirrer?
From Wikipedia: A magnetic stirrer or magnetic mixer is a laboratory device that employs a rotating magnetic field to cause a stir bar (also called "flea") immersed in a liquid to spin very quickly, thus stirring it. The rotating field may be created either by a rotating magnet or a set of stationary electromagnets, placed beneath the vessel with the liquid. Since glass does not affect a magnetic field appreciably (it is transparent to magnetism), and most chemical reactions take place in glass vessels (i.e. see beaker (glassware) or laboratory flasks), magnetic stir bars work well in glass vessels. On the other hand, the limited size of the bar means that magnetic stirrers can only be used for relatively small (under 4 liters) experiments. They also have difficulty dealing with viscous liquids or thick suspensions. For larger volumes or more viscous liquids, some sort of mechanical stirring is typically needed.
May 01, 2013 | Science & Laboratory
I have the grind and brew thermal coffeemaker. The water does not get hot enough for steam to come off of the coffee when it is poured.
Hi, I have owned that coffee maker for years.
After it brews coffee, it does not have a warmer to keep it hot. It has a thermally insulated carafe. Such as regular lunchbox thermos jugs have. The reasoning behind this is that coffee heated after it is brewed spoils in a short time. (Of course, unheated coffee gets cold).
What that translates to for you with regard to no steam is this. As soon as the coffee maker finishes brewing your coffee, open the top of the carafe, stick in a spoon and stir it.Then pour it. (I learned the stirring part working in a restaurant).
If you have to wait before you drink it, do the same. Stir it first.
Hope this has been helpful
Love that grinder!
Best Regards,
Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Kitchen Appliances - Others Logo
100 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
