Question about Music
Convert 400g cream cheese into cups
400g to cups
  • 5 Answers
Slightly less than 2 cups
Posted on Dec 05, 2016
    Top Expert:
  • Music Master
  • 77,186 Answers
1.9 cups.
How to fix chauvet CH460LS
*BUMP* I, too, have a dead channel on my Chauvet CH-460LS Controller-Dimmer.
Jun 05, 2014 | Chauvet Followspot 400g with Stand
FAN NOT WORKING
replace fan if the follow spot is working. if not check power supply.
Apr 09, 2014 | Chauvet Followspot 400g with Stand
The bulb and fuse keeps blowing out at the same time
Verify that you have the correct fuses and lamp. install the fuse(and only the fuse,no lamp) and fire it up.listen for the fan.if the fuse holds and the fan runs, you probably have an issue with the dimmer on the main board. Chauvet may be able to send you a new one, but this model was discontinued in 2012, which may parts hard to get. Good Luck!
Oct 14, 2013 | Chauvet Followspot 400g with Stand
How to make followlight with colours?
With DMX controller you command the color wheel within the unit to the desired color. I don't know if you can do this without a controller.
Apr 24, 2011 | Chauvet Followspot 400g with Stand
How to make follow spot with colours?
on the control panel, use the Function Select button to set it to manual mode. Now, the color buttons on the panel should control the colors.
Can the color wheel be replace?
The short answer is yes, but that opens up more questions.
1) Is this unit under warranty? If so, opening it up will void hte warranty.
2) Are you sure that the color wheel is the problem?
Can you describe the problem you are having? Perhaps there is another solution.
Thanks,
Dan
Dec 07, 2010 | Chauvet Followspot 400g with Stand
The light is not working and the bulb is not blown.
These systems have many interlocks for safety. All doors must be closed completely. Also, there is usually a thermal fuse inside that may be blown. Did this stop during use or was it shutdown and now won't start again? If it was shutdown, perhaps it was unplugged before the fan stopped. If that is the case, the thermal fuse is likely to have been blown and will need to be replaced.
Let us know what you find.
Dan
May 13, 2010 | Chauvet Followspot 400g with Stand
It wont change colors
Make sure you are in manual mode with the Function Select button on the control panel.
Mar 11, 2010 | Chauvet Followspot 400g with Stand
I am trying to connect a Chauvet Followspot 400G to an Elation Sc
Just follow the details below to set your spotlight.
The TFX-FS360 utilizes 2 DMX control channels.
Channel 1 is for the colour.
Channel 2 is the dimmer.
1) Press the FUNCTION button until the DMX Mode LED turns on.
2) Press the UP or DOWN buttons until the starting channel address you desire is located on the digital display. eg 19
Regards
Jon
Feb 28, 2009 | Chauvet Followspot 400g with Stand
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
