My inside fan motor turns slow and will come to a stop kick back slightly and then turn slow again. It does not turn fast enough to blow air.
    Top Expert:
  • Heating & Co... Master
  • 77,932 Answers
Replace the fan motor.
Posted on Dec 05, 2016
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
I have a shenbao mennelium aircon its gets cool after i turn the unit on but after 10-15 min it stops blowing cold air i have to shut the unit off and then back on to get cold air and also the compressor...
Check the fan,to make sure it is really turning fast on the high mode with ac on,not just fan.It sounds like the fan is slowing down,and not cooling the condenser,therefore cause the head pressure to rise,and producing warm air.The fan motor would have to be replaced to fix the problem if this is the case.
Apr 16, 2012 | Heating & Cooling
I have a 2002 Dodge Ram Quad Cab 4x4. The a/c runs great as long as the truck is moving, but as soon as you come to a stop it starts blowing warm air. Please help.
Generally if the a/c works fine at highway speeds but kicks out or slowly begins to blow warmer and warmer air as the vehicle is driven at slow speeds or is stopped the a/c condensor cooling fan is usually at fault. At highway speeds there is enough air being forced through the radiator, condenser, and oil coolers to keep everything working and cool but when the vehicle is moving slowly or is parked the electric and mechanical cooling fans have to be working to pull enough air through to keep things working. If the cooling fan isn't working or can't pull enough air through the a/c condensor the system will kick out once the internal pressure reaches a certain point. Once the vehicle is moving again the system can get rid of the heat that it has gathered from the passenger cabin, the pressure drops back to normal and the system cools again. I would start by looking for a blown cooling fan fuse in the fuse panel under the hood. Usually they are 25 amps or larger and run only the cooling fan.
Jun 14, 2010 | 2004 Dodge Ram 1500
Everstar MPK-10cr blowing hot air
Sound like the back lower motor that turns the fan wheel in the back has failed or needs to be lubricated. I used a little bit of silicon spray since it resists moisture. You can try taking the back off...then the front...then take loosen the front motor fan wheel housing and lift up enough to access the lower back fan motor. I then sprayed the motor housing openings as close to the inner part as possible. That also stops the common noisey fan issue.
Jul 20, 2009 | Heating & Cooling
Heater fan blowing intermittently or not at all
unhook your battery unplug the harness that's touchy get a sharp object that you can pry the connectors together with you will see them wide open crimp then tight enough to get a good tight fit, the amperage draw from the motor has stretched them out and when it gets warn with current passing threw it opens up and loses contact. while it's apart take a emory board and clean the flat spades on the other side so you have a good connection.
May 30, 2009 | 2000 Pontiac Sunfire
2001 Jeep Grand Cherokee Laredo Overheating
Three possible solutions:
1. Bad Thermostat
2. Fan Relay (most likely)
3. Bad Fan
When the GC reaches a temp of 180 Deg. F the fan relay sends a signal to the fan to turn on, once the temp lowers (around 155 Deg. F) the relay turns off the fan, and so the cycle continues. If the relay is bad there will be no signal to the fan to run. While you are driving your vehicle there is ambient air moving thru the radiator, cooling the engine, but once you encounter slow/heavy traffic or stop there is no air moving and the temp goes up, the fan will not kick in and the vehicle will overheat.
If the fan motor is not working the same will happen, but a more expensive fix, as the motor comes with the fan.
If the Thermostat is stuck in the open position, the water travels to fast in the engine and heat exchanging is not an efficient process, therefore the vehicle might overheat when stopped or in slow traffic.
Mar 31, 2009 | 2001 Jeep Grand Cherokee
Most likely it does, if you can hit the motor and it will run. I can't say for sure but you might want to chk. to see if you got a heater blower motor resister. There located (if its got one) around the heater motor and it controls blower speeds, might be worth checking out.
Jan 31, 2009 | 2000 Pontiac Sunfire
Outdoor fan motor is not running fast enough?
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
Oct 15, 2008 | Hitachi RAS-09UH Air Conditioner
Fan or capacitor?
I would say the motor is bad but to be sure test the voltage to the motor with a multimeter, you can also phisically spin the motor and if that makes it work a little not as fast and blow enough air then you know its the motor this works if you dont have a multimeter.
Dec 09, 2007 | Whirlpool Electronic Window Air...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
