Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
How do I replace a broken negator spring on a paslode angled finish nailer IM250A
5 Suggested Answers
wwwwspirax
  • 7 Answers
SOURCE: Paslode Impluse Finish Nailer, fan does not run.
make sure the new fuel cell top part is firmly pressed in to the fuel cell
Posted on May 17, 2009
jmillward330
  • 6 Answers
SOURCE: paslode shoots a few nails and quits
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Posted on Aug 16, 2009
heatman101
  • 43501 Answers
SOURCE: my paslode angled finishing gun keeps jamming
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
SOURCE: I have a paslode finishing nailer that is occasionally firing. If i jam it hard it will shoot. #902000
You can adjust the settings arm on it to make it shoot out easier look on YouTube it may be there
Posted on Jan 22, 2015
Testimonial: "Thanks for the suggestion.I will try that."
My paslode IM250A when charging flashes red and green back and forth is that a bad battery
The battery may be the culprit but more common is the fan motor. When the fan motor fails it will alternate red/green. The part is pretty expensive and is fairly involved to replace if you are not familiar with the tool.
Paslode nbsp900600 nbspImpulse Cordless 16 Gauge Angled Finish Nailer...
You need to remove the head cap, unplug the spark and fan wires, twist the fan assembly a few degrees to the left and it will lift straight out of the tool. Carefully remove the fan blade by loosening the tiny torx screw located on the side of the fan shaft being careful not to bend the fins.
Release the retainer on the top of the motor holding it in, unplug the motor wires and then slide it out.
Inside the motor housing is a plastic bushing that needs to be removed and replaced (part will come with the new motor).
Reverse directions to reassemble
Let me know if you have any other questions
Mar 04, 2017 | Air Tools & Compressors
Paslode IM250A nails jamb
Sounds like You need feeder spring. Is driver blade going all the way back up?
-Jeff
Mar 18, 2014 | Air Tools & Compressors
My paslode im250 will not punch pin home
The Paslode gas powered tools need to be thoroughly disassembled, cleaned, and lubed periodically. If you are running the correct gauge nails (16 gauge, straight finish nails for the IM250 and angled for the IM250A) and the tool appears to be working correctly then this is probably what it needs. I do quite a few of them here at my shop and it is the most common problem.
Feb 03, 2012 | Tools & Hardware - Others
I have a paslode 900600 . It cycles but it won't shoot nails.
heatman101
Jan 18, 2011 | BreatheAudio Paslode 900600 Impulse 16...
My paslode angled finishing gun keeps jamming leaving the firing pin in the out position
heatman101
Dec 24, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Fan goes on,only fires at a certain angle.
heatman101
Sep 20, 2010 | BreatheAudio Paslode 900600 Impulse 16...
The follower spring is broken, this pushes the nails up to the top. I cannot remove the follower from the spring buttons in the handle
what is the exact model number on the framing nailer you have to pry the push nut off the shaft and on the finish nailer you remove the screw and then the handle. let me know and I will try and help
Jan 26, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I can't put mt paslode finish nailer back together again
go to Paslode.com and you can download a manual that shows the spring. It sits in a recess under the follower that pushes the nails
Jul 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
124 people viewed this question
Top RTO Tools & Hardware - Others Experts
yoopertech
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
